internal wiring handlebars
Old Feb 28, 2013 | 01:18 PM
Jaystn62's Avatar
Jaystn62
I cut,soldered then heat shrink tubing in bars on mine. was a good solid job on both sides and had enough extra that there's no stress on wires at bottom of bars.
Old Feb 28, 2013 | 01:46 PM
jmeiers's Avatar
jmeiers
And there is nothing wrong with that, I just feel that it adds more points of connection failure. It's best to keep the cutting/shrinking points to a minimum, when possible, but if its done right on each connection, there should be no issues whether there is one connection or one hundred connections.
Old Feb 28, 2013 | 02:49 PM
GeneBinderFXDB's Avatar
GeneBinderFXDB
Thanks for the input guys. I actually went to this computer micro center today to look for electrical wire that is thinner than the wire i used from homedepot and saw a variety of those pins for sale and adapters. Not sure if it will work for the guys who said they broke theirs, but I figured it was worth a try before taking a trip to the dealership. Two follow up questions: What are the gauges of wire used in these connections? and will the WD really have a serious impact on the wires? I was able to get 14 gauge through with all of the wires but it is a really tight fit. I may try and rewire them with thinner wire....especially if all of these connections are going to dry out and crack
Old Feb 28, 2013 | 03:02 PM
JRK5892's Avatar
JRK5892
the wiring must be able to handle 12v. going thinner is not really so much as better. do you have them in some type of covering? shrink wrap or cable cover? if not i would at least flush them before putting them back on, i have seen some pretty nasty wires pull from inside bars that where lubed with WD during install, the cable covers hardened and cracked exposing wires and shorting out on the bars. *i will say this was also 2 years after it was originally done so i do not feel you have anyting to worry about right NOW, but down the line it may or may not become an issue. just something to beware of*
on the wiring, again do not just go thin make sure it is 12v approved, i like to stretch my lines, (solder in my extension) then wrap them with shrink wrap so that they are 1 solid line... baby powder the shrink wrap cover and put some down the bars... drop a pull chain like you use on a house fan down from the grip to the center, attach string... do both sides... then tie the string to the wire, run some electrical tape around that so the pull is smooth, and pull it though. after both sides are though, blow out the bars to get out the left over baby powder and plug back into the connectors. if you drill the bars yourself that is no problem just be sure you can pull a cotton ball though and not have it get hung up, any sharp edges will wear though and short out the bike.
Old Feb 28, 2013 | 04:07 PM
GeneBinderFXDB
thanks Joe. I am going to redo it with thinner, 12V approved 16 gauge, wire and try and get the WD40 out before. One thing that might help others with this project a little trick I used after getting very frustrated with the 'string technique. I used very thin wire that I had around as the guide. The wire is thin, malleable, and very strong. I actually soldered the wire to the end of the wires I was pulling. This provided the strongest grip vs. anything else that I tried which would just pull apart inside of the bars during a 'traffic jam'. Just something to think about.
Old Feb 28, 2013 | 04:47 PM
JRK5892's Avatar
JRK5892
good idea! i actually use a old bicycle shifter cable on z bars for the same reason. works really good! let me know if i can help at all buddy
Old Mar 4, 2013 | 09:40 AM
GeneBinderFXDB
I finally got them done. I used a four color wire combo pack i purchased at advanced auto which is made to wire trailers. It comes in attached 4 wire clusters. This was the key to saving me hours. The wires being attached to each other made it very simple to pull through the bars. I used a black gasket sealant to make sure everything was completely water proof. I also rewired my turn for a more stealthy look. I bent some L brackets from Home Depot and attached the turn signals to the headlight mount. I put up some pics.
Old Mar 4, 2013 | 10:26 AM
Shrug's Avatar
Shrug
Nice work! Creative use of the trailer wiring too!
Benway
Apr 9, 2014 11:39 AM
jmaxx24
Dec 8, 2012 05:55 PM
dhamilton20
Feb 25, 2010 08:25 PM
Dyna2007
Dec 27, 2009 07:34 PM
GPHDXLC
Dec 26, 2008 12:56 PM
