FXDB lower shock bolt
Old Mar 4, 2013 | 06:13 PM
SLV's Avatar
SLV
Default FXDB lower shock bolt
Does anyone know the diameter and thread pitch for the lower shock bolt on the 2013 Street Bob?
I need a longer one on the left side. While I'm at it, I want to replace both to get rid of the torx.
Old Mar 4, 2013 | 08:46 PM
rs87277's Avatar
rs87277
Take out ur current one out and hardware stores have the thread inserts to check on
Old Mar 4, 2013 | 08:54 PM
SLV's Avatar
SLV
Good thought, but the nearest store is a few miles away and the SB is my only vehicle. I was hoping for a confirmed size so I could have them on hand before taking the old bolts out.
They are either 1/2" x 13 or M12 metric. I'll just pick up a couple of each.
Old Mar 4, 2013 | 09:04 PM
nevil's Avatar
nevil
That bolt has a 1/2-13 thread.
Old Mar 5, 2013 | 04:35 AM
Jacoblb's Avatar
Jacoblb
1/2-13 x 2 1/4
Old Mar 5, 2013 | 06:33 AM
SLV's Avatar
SLV
Thanks a lot.
Old Mar 5, 2013 | 10:59 AM
rs87277's Avatar
rs87277
this forum is awesome for info like this
Old Mar 5, 2013 | 12:27 PM
SLV's Avatar
SLV
I agree. Now, if Lowes would just stick the right length.
Old Mar 5, 2013 | 12:33 PM
Bretley's Avatar
Bretley
Do you need a longer one for installing a license plate mount. I have a badlands plate mount on order.
Old Mar 5, 2013 | 12:45 PM
vonh's Avatar
vonh
Go to a machine shop and get the right bolt for the job. A bolt isn't just a bolt! You also need the right strength bolt or the one you put in might break and cause a problem.
