primary oil question
Old Mar 10, 2013 | 08:26 PM
Rhino200099's Avatar
Rhino200099
Default primary oil question
What primary oil is every one using out there? Ive seen alot of diffrent things from 20-50 to trick shift atf. I just removed my primary cover to install forward controls so i need fluid what is best to put in there?
Old Mar 10, 2013 | 08:39 PM
RAWHIDE07's Avatar
RAWHIDE07
I don't know whats best but I just use HD Syn3 20w50 which is approved by Harley and is the same oil I use in my motor. It's mainly to lube the primary chain so I have no qualms about using it. For my tranny though I use Spectro 6 speed.
Old Mar 10, 2013 | 08:40 PM
dirtdobber's Avatar
dirtdobber
Well I am old school so what I do is probably different from most and how I see it.
Stock clutch with mild build I use either 20-50 or HD standard primary/transmission fluids.
The primary is nothing but a oil bath.
Big build trans fluid.
Old Mar 10, 2013 | 08:42 PM
QC's Avatar
QC
20W50 Valvoline full syn here.
Old Mar 10, 2013 | 10:21 PM
CB024's Avatar
CB024
I have been running Rotella.
Old Mar 10, 2013 | 10:29 PM
Bigman405's Avatar
Bigman405
I use Revtech high performance primary lube.
Old Mar 10, 2013 | 10:33 PM
izzyryder's Avatar
izzyryder
I use Mobil 1 full syn 4T 10w40 in mine, but only because I scored some at a good price. Been using it for a few years now and can't say a bad thing about it, great stuff.
A lot of peeps also use Rotella 15w40...
Old Mar 10, 2013 | 10:42 PM
Id.Fat Bob's Avatar
Id.Fat Bob
I use oil specifically formulated for primary chain life and clutch operation. I believe the inner primary bearing gets lubed by the same oil. I have used it now in 2 different Harleys and noticed improved operation of the clutch and transmission shifting due to clean clutch plate brake-away and reduced primary noise. In my travels and to my knowlege, Bel-Ray Primary Chaincase oil is the only product that is for chaincase use only.
It's the good stuff!
Old Mar 11, 2013 | 04:35 AM
Spanners39's Avatar
Spanners39
I use Valvoline 75W-90 gear oil in the primary (I get it cheap with my trade card at Repco) and Spectro Gear Guard in the tranny because it fits my worldview on what tranny oil should be like......thick, basically :-)
Old Mar 11, 2013 | 06:30 AM
rs87277's Avatar
rs87277
basic harley stuff,
