Primary tower gasket leaking
Old Aug 1, 2017 | 06:46 PM
Schocker65's Avatar
Schocker65
Sorry to bring up a dead thread here, but I have a leaking tower gasket issue.
I have an '07 FXDC with mid controls, and the tower gasket was leaking (noticed shortly after taking delivery).
Just replaced the gasket this past Saturday night - cleaned the tower surfaces well and adhered the gasket to the inner primary tower, being careful not to damage it as I slid it over the shifter shaft. The gasket seemed to be well adhered to the tower.
Carefully replaced the outer cover, following the proper torque sequence and bringing to 108 inch pounds. Replaced the shifter and foot peg and filled with fluid.
Took for a ride the next day, and there is still oil coming out, although more slowly than before. Not sure if perhaps it is residual oil that remained in the tower from before? Maybe the gasket will swell a bit in time and it will stop? Wishing it could be so, but I fear that is not the case.
If this continues to leak, I will take another swing at it. Would appreciate any advice anyone may have to ensure that this frickin' gasket actually does the job it is supposed to.
Before you suggest it, I really have no interest in forward controls, so not a solution for me.
Thanks in advance for any help you can offer.
Old Aug 3, 2017 | 04:59 PM
Schocker65's Avatar
Schocker65
Update for anyone who cares or could learn from it - my leak appears to have stopped. Not sure which of my theories might be correct, but I am happy for the moment that the leak is gone.
Old Aug 6, 2017 | 01:39 PM
Schocker65's Avatar
Schocker65
Going to continue this monologue for a bit - went out for about 130 miles this morning, and it's still leaking. Fudge.
My next attempt will be using a Genuine James gasket with just a bit of Yamabond on the mating tower surfaces in hopes that it will keep the gasket in place and leak tight.
Old Aug 7, 2017 | 02:40 PM
danocoyote's Avatar
danocoyote
I have an 07 FXD with forwards, and my tower gasket was leaking last year. Need to make sure that the gasket isn't compromised or out of place. That tower gasket is a pain! Good luck!
Old Aug 15, 2017 | 07:16 PM
Schocker65's Avatar
Schocker65
So I went back in last night and took another shot at stopping the leak. This time used a Genuine James gasket at the tower with a thin layer of Yamabond 4 on both inner and outer tower faces.
I should mention that the replacement that I had just installed a couple of weeks ago was still properly positioned/adhered and appeared to be in good shape. It was squished pretty flat, though.
Also used Spectro primary fluid when refilling, replacing the Syn3 that I had put in there - had great results with Spectro products in past history WRT shifting and clutch performance.
Took it for a spin tonight and all is well so far, but not enough riding to expose the leak if it is still going to happen. Shifting is indeed a bit quieter and clutch engagement a bit smoother with the Spectro.
I'll report back after a couple of commutes and let you know what's up with the leak.
Old Aug 17, 2017 | 07:44 PM
Schocker65's Avatar
Schocker65
Two commutes later (~100 miles total). No leaking. Keeping my fingers crossed.
Old Aug 17, 2017 | 08:13 PM
Dalewyatt's Avatar
Dalewyatt
5th Gear
My 2007 Lowrider is also leaking at the tower gasket after forwards. Being fixed tomorrow.
astark
EVO
14
Sep 1, 2016 02:34 PM
harleyheaven
Jun 27, 2012 08:55 PM
redman53
Jul 16, 2011 04:59 PM
skidsareforkids
Aug 30, 2010 05:33 PM
toadmanor
Jul 9, 2009 09:35 PM
