exhaust ????
Old Mar 28, 2013 | 05:01 PM
PistolPete83's Avatar
PistolPete83
Default exhaust ????
The flange on my front eexhaust header is not flush against the motor. I tried tightening both nuts but they seem tight. Any thoughts on weather this is ok???? Thanks
Old Mar 28, 2013 | 05:10 PM
Stangheel's Avatar
Stangheel
any work done on it lately? kind of weird to work loose to where it's not flush but the nuts be tight. My guess would be it was put on lopsided. I'd take it off and reinstall it to see if you can get it flush.
Old Mar 28, 2013 | 05:18 PM
PistolPete83
If I don't pull of the head pipe. Will the gasket be fine??
Old Mar 28, 2013 | 05:22 PM
Stangheel's Avatar
Stangheel
most likely it will be fine. There will be some to tell you they replace the gasket whenever they pull the exhaust. I do this as well, but if you just pull the flange and not the pipe then you should be fine.
1Cardiac
Exhaust System Topics
Aug 7, 2017 11:08 AM
peeweesenior
Aug 26, 2012 10:28 PM
tinsley
Oct 19, 2010 04:24 PM
lefty9425
Sep 27, 2010 09:33 PM
RidemyEVO
Mar 9, 2010 10:02 AM
