windshield problem, need help
Old Apr 14, 2013 | 07:01 PM
tfalcon's Avatar
tfalcon
Default windshield problem, need help
Ok so I bought this used windshield off of ebay and the guy said it was for a dyna with 49 mm forks. Well it comes in and it doesn't fit. Looking at the clamps they have the number "52" stamped on them so I assume they are for 52 mm forks, ok no big deal I hit up surdyke and got some new 49mm clamps. I get the new clamps in and they are totally different than the 52mm ones?? They look the same but the mount where the screw goes is on the totally opposite side of the mount than the other one, and no matter how I mount them up they wont work.
The new camp is on the top, the old one is the one with the screw in it. In this pic they are both arranged so they open on the same side. But you can see on the new one the mount is on the opposite side.
Here they are aligned so that both screw mounts are on the same side.
So what should I do? The seller of the windshield was an asshat and I can't return that, and I guess I'm gonna have to try to sell the new clamps I bought on my own cause I cant return those either. Are there another set of clamps I can get? or am I screwed? Sucks too cause I really like the shape and size of the windshield.
Old Apr 14, 2013 | 07:40 PM
Spanners39's Avatar
Spanners39
You could make some wrap-around spacers to put on the forks under the clamps. its only 1.5mm spacer thickness. Some stick on rubber or foam would do it.
Old Apr 14, 2013 | 08:57 PM
tfalcon's Avatar
tfalcon
Well I would like to try to get the right parts first.
Old Apr 14, 2013 | 09:26 PM
Puffdaddy's Avatar
Puffdaddy
If it differs from the description you can try to get a refund from PayPal. It doesn't matter if the seller posted "no returns" if it was not honestly listed. Usually the seller will try to make good if threatened by PP. If he doesn't, you may get a refund and keep the shield (I had this happen on a set of mountain bike wheels).
The clamps from Surdyke are like all the others I have seen. Are you sure it is an HD shield?
Old Apr 15, 2013 | 02:50 AM
tfalcon's Avatar
tfalcon
Well I kinda screwed myself cause I left positive feedback before I checked fitment. It is an HD shield, but has no part number on it.
Old Apr 15, 2013 | 04:32 AM
vonh's Avatar
vonh
Go to a machine shop and pay the guy to mount it, if you can't figure it out yourself. An xtra $100 bucks won't break the bank and you'll have the windshield you want
Old Apr 15, 2013 | 06:16 AM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Top ones are the right style. I have these on my '06 49-mm Wide Glide forks. But Wide Glide are wider-spaced fork tubes than other Dyna models, so "Dyna 49-mm" doesn't guarantee fit.
An FYI: When mounting a 'shield with these cam-lock brackets, if the bracket isn't VERY perpendicular to the fork tube, the clamping finger will break, and HD doesn't sell that piece; you gotta buy a whole clamping bracket. I snapped one and had to buy a new one, and the parts guy explained this tip to me. I decided to fab a new finger from some scrap aircraft aluminum. Super-glued the broken piece back together (see glue line on top part of 1st pic), used it as a template to scribe and mark holes on the scrap aluminum, drilled holes first, rough-cut the shape on the bandsaw, coarse-shaped on grinder, fine-shaped with files, sandpaper, buffer...about 3-hours time invested but it works perfectly, with the same cam-lock feel as factory piece. I should'a waited until after polishing before I took the photos; shined up close to the chrome one. Yep, pretty proud of my handiwork on that one! Now have a working spare, in case I get careless [again] locking the 'shield on.
crash xl1200c
Feb 29, 2016 12:40 PM
Stopit
Jan 12, 2016 03:44 PM
WideGlideFever
Mar 7, 2013 05:15 PM
JRK5892
Oct 20, 2010 04:43 PM
2007z71
Jun 17, 2009 06:49 PM
