Speedometer quit working! Help
Old May 5, 2013 | 04:34 PM
cpitts118's Avatar
cpitts118
Default Speedometer quit working! Help
While riding down to Florida my speedometer, neutral light, and 6th gear indicator all stopped working. It's a 2011 wide glide. Still rode 700 miles without it. Any ideas what it could be? I was thinking the speed sensor but one of the guys at Harley said it could be because of a bad turn signal modulator or the speedo its self could be bad. I really don't want to pay $100 an hour for them to figure it out.
Old May 5, 2013 | 04:35 PM
cpitts118's Avatar
cpitts118
I did check all connections to make sure nothing came loose.
Old May 5, 2013 | 04:55 PM
Robtarra39's Avatar
Robtarra39
Fuse maybe
Old May 5, 2013 | 06:04 PM
Chase1961's Avatar
Chase1961
Depending on when you bought it, it should be a warrenty job. I had to have my speedometer unit replaced less than a month after I bought mine.
Old May 5, 2013 | 07:53 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Pull the sensor out of the top of the trans cover, sometimes some crud covers the pickup.
Old May 6, 2013 | 12:58 AM
VibratingPotato's Avatar
VibratingPotato
I'm with this guy.
When my speed sensor went bad on my '08 I was told to check for metal shavings on the sensor. I didn't have anything on the sensor but it was bad and when I replaced it, all was well.
I don't think my neutral light went out, but the speedo, 6th gear indicator and cruise control stopped working and the engine wanted to die.
Good luck.
Old May 6, 2013 | 03:20 PM
six_strng_slnger's Avatar
six_strng_slnger
mine was a bad accessory fuse but mine is older 2001 fxdwg
Old May 6, 2013 | 05:08 PM
Harley Tim's Avatar
Harley Tim
All that would make me want to take a good look at the ground (Including bonding jumpers)...
Just a thought....
Best wishes....Tim(HT)
Rathgar
Aug 24, 2019 06:36 PM
ROLLn1
Apr 15, 2014 06:37 PM
jdh1340
Jun 13, 2011 10:57 AM
Gpsjr10
Jun 12, 2011 02:42 AM
Deuce00
Jan 3, 2008 08:35 AM
