new bars new problem
Old May 14, 2013 | 05:35 PM
Blackest's Avatar
Blackest
Default new bars new problem
So I laid my bike down a few weeks ago, I bent the handlebars and I just got a new pair. But now I think I bent more than just the bars . My handlebar clamp seems to be bent, or something is out of alignment. These pics are with the wheel pointed straight forward. What do you guys think?
Attached Thumbnails new bars new problem-20130514_144242.jpg   new bars new problem-20130514_144256.jpg
Old May 14, 2013 | 05:40 PM
byrdman.45's Avatar
byrdman.45
Did the same thing to one of my XL's and to re-align the tubes to the trees. I'd try that first.
Old May 14, 2013 | 08:41 PM
mbutton65x's Avatar
mbutton65x
Looks like the risers are twisted in the bushings, turn your bars all the way to the right and twist them back, just like a dirt bike lol
Old May 14, 2013 | 08:49 PM
topdwg's Avatar
topdwg
The trees look to be off. Just put a jack under the bike and raise up just until it puts little pressure on the bike. Then loosen the tree clamps and have someone straddle the tire while you straighten everything back up. If you do not put the jack under the bike when loosen the tree clamps your fork tubes will slide up. Not a big deal, you'll just have to slide them back down. My manual for the Fat Bob says the top of the fork tube should be .50 above the top triple tree...
Old May 15, 2013 | 05:49 PM
Blackest's Avatar
Blackest
I tried this and it didn't help. I think its the handle bar clamp and bushings. I tried turning the bars all the way right as suggested and it felt like if I turned any harder I would have bent the bars. I can't find anything in my HD service manual about this problem. Any other suggestions?
Old May 15, 2013 | 06:04 PM
schitty's Avatar
schitty
Pull the risers off and inspect the bushings. Just taking them apart and putting them back together might straighten them up. Worked back in my motocross days.
Old May 15, 2013 | 06:21 PM
Blackest's Avatar
Blackest
I tried that quite a few times after reading this thread: https://www.hdforums.com/forum/softa...crooked-3.html
I tried different tightening sequences as that thread suggested, and it cant be the handle bars being bent from the factory because its obviously not the bars that are out of line. Like I said; I cant find anything in my service manual about this and I know it wouldn't be covered under my warranty since I dropped the bike. Id like to figure this one out without having to pay the stealership $75+ an hour. I also installed new poly bushings when I did the bar swap. I am kind of stumped at this point, hopefully someone can help me out.
Old May 15, 2013 | 06:25 PM
Robtarra39's Avatar
Robtarra39
have you tried loosening the top clamp twist the bars and then retighten the top clamp
dbeach2014
General Topics/Tech Tips
Mar 4, 2015 01:34 PM
3bc
Nov 7, 2014 04:56 PM
harlot
Feb 5, 2012 10:24 PM
bluemotev
Nov 3, 2007 08:30 PM
mhughes600
May 15, 2006 02:08 PM
