Forward controls
Old Jun 17, 2013 | 05:45 AM
Andrew17019's Avatar
Andrew17019
Originally Posted by Paulflhx
Removal of the primary is only needed if you want to remove the shifter spline that passes through the primary in one piece. You could use a hacksaw blade or sawzall to cut it off behind the primary and then pull it out. However,there is no need to remove it at all, regardless of what all the installation instructions state. Just fastenen the arm so it doesn't rattle and leave it there.
Is this still possible with a new primary cover that is built for forward controls? I thought the old mid shafts would have to be removed for it to fit, but if it can just sit there I'd rather go that route.
HDJeff14
Dyna Parts
Jun 18, 2019 07:31 AM
d24112
EVO
Mar 22, 2019 10:51 AM
rlbailey
Oct 29, 2011 12:30 PM
jrsmith_80
Oct 15, 2007 08:30 AM
xmeter
Dec 1, 2006 04:27 PM
