oil change issue
Old May 27, 2013 | 06:18 PM
smokinfromshootin's Avatar
smokinfromshootin
Default oil change issue
so i have run into an issue changing the oil on my '11 fxdb. the rubber bumper or whatever that keeps the kickstand from banging on the frame is in a spot where I can't fit a ratchet in there. i know I can use a regular open wrench, but is there a way to pull that bumper off and then put it back on?
Old May 27, 2013 | 06:23 PM
ynots's Avatar
ynots
I take mine off every time I jack up my bike or change the oil. Just take note of the position its in.
Old May 27, 2013 | 06:24 PM
smokinfromshootin
did you just pull it off?
Old May 27, 2013 | 06:26 PM
ynots's Avatar
ynots
To remove mine I just twist on it while pulling. If I forget to remove it it will usually pop off when I try to jack up my bike
Old May 27, 2013 | 06:28 PM
smokinfromshootin
cool, thanks man. last time i forgot to tighten the plug down after changing the oil. lost the plug, the oil and got a real nice burn on my forearm leaning against the exhaust cleaning up the oil. got it tattooed over as a reminder.
Old May 27, 2013 | 06:49 PM
ynots's Avatar
ynots
Ouch! I cringe every time I see some idiot riding in cutoffs. I never fudge on wearing boots and pants, everything else optional. Don't get carried away when tightening up that drain plug :-) Ride safe
rage4order
Oct 2, 2014 04:57 PM
08HD
Dec 9, 2008 03:01 AM
jackinthebox
Dec 4, 2008 09:58 PM
petemac
Sep 24, 2007 07:21 PM
SportyPig
Nov 8, 2006 10:53 PM
