A strange problem, need the forums collective knowledge..
Old Jun 4, 2013 | 10:01 PM
HooliganCycles's Avatar
HooliganCycles
i had a customer bring in his bike, doing exactly the same thing. he would lug his bike a lot and it caused a lot of carbon to build up in the cylinders and around the valve seats. a pretty easy fix for that is to pull off the air cleaner and rev the motor up while you are spraying cold water straight into the throttle body, the cold water crystalizes the carbon and it breaks loose and blows it all right out the exhaust pipe. fixed his bike in about 10 minutes. and it has worked countless times on a lot of old hot rods. you just have to make sure to rev it high enough so that the bike doesnt die when you spray the cold water in it. good luck, let me know if that fixes it
Old Jun 4, 2013 | 10:11 PM
lo-rider's Avatar
lo-rider
Sounds like a good way to wreck your motor.
Old Jun 4, 2013 | 10:28 PM
Dangermouse's Avatar
Dangermouse
Exactly my thought! If you are talking about a fine mist from a spray bottle, then it probably won't wreck your motor, but spraying water, like say with a hose Definitely will! Motors are basically compressors and water doesn't compress. I'm not saying a light mist won't work. I don't know, never heard of it, but if you spray water in your carb, you are asking for trouble... IMHO
Old Jun 4, 2013 | 11:50 PM
Spanners39's Avatar
Spanners39
You can buy a de-carbonising spray if the water thing scares you.
Water injection used to be a common performance mod on many cars, especially SAAB 9000 series.
Old Jun 5, 2013 | 10:41 AM
HooliganCycles
yes its from a spray bottle, not a hose, kinda figured that went without saying. it doesnt take much, as Spanner mentioned its not an uncommon thing on performance cars, also on a lot of airplanes. just trying to help with a solution that like i said has worked countless times in the passed. you could also take the top end apart to check if that makes you feels better, but this way is fast and doesnt hurt anything
Old Jun 5, 2013 | 04:19 PM
Dangermouse
Sorry if I came across harsh, just imagined this guy spraying water in his carb with a hose... Also am not trying to insult OPs intelligence as I don't know him,.... But that said I have seen people do some really crazy **** and was trying to make sure it didn't go wrong because of a misunderstanding.
Old Jun 5, 2013 | 04:42 PM
Simple Man's Avatar
Simple Man
As I was reading through the replies, (a lot of good ideas), I was thinking a valve seat issue. Has anyone done a leak-down test? I don't disagree with the carbon idea but since it has done this since new I would lean toward the seat itself. I have seen seats pop out on small engines before and then fall back into place and run fine for a while. (wouldn't have believed that without seeing it). It's a stretch, but worth checking if everything else fails.
Otherwise, get a priest. It may either need an exorcism, or last rites. Sorry, I couldn't help it.
Be sure to let us know what you figure out.
Old Jun 5, 2013 | 09:16 PM
hell hound's Avatar
hell hound
does it happen at all rpm's ? you said it runns better when you down shift
Old Jun 5, 2013 | 10:54 PM
HooliganCycles
no worries, i wasnt tryin to come across harsh either....i agree, i have seen people do some really stupid things when it comes to workin on their bikes
Old Jun 6, 2013 | 09:15 AM
Krazy8s's Avatar
Krazy8s
Last night I pulled apart the ECM connector and cleaned all the contacts (they didnt look it needed it but i did it anyway).
Did a tour of all Earth and ground points, pulled them, cleaned up with a wire brush and contact cleaner (lugs and bolts).
All ran fine from my workshop to home, and i was thinking it might have come good.
This morning I fired it up, got about 100 yards from home and it started acting up again.
On the way to my shop this morning there is hill with a reasonably steep descent, dropped it down a gear into a hard engine brake and it came good again. So back to square 1.
I'll be getting some injector cleaner today and run that through to see if it helps.
My Indy called me this morning, said this issue is bugging him as he couldnt diagnose it. He wants me to take the bike back next week and leave it with him for a few days. He wants to ride it for a day or so, get it to misbehave, and see if he can nut out the issue.
@Hell Hound, doesnt seem to matter what Rev range or gear I'm in when it acts up. Dropping it gear whilst going downhill and letting the engine brake hard, and subsequent high revs seems to sort it out. Giving a good Rev on a flat road doesnt seem to do anything so I am thinking that the compression from engine braking is the key to sorting out whatever the prob may be.
I am starting to think I may have an intermittent gasket leak, or something compression related. Then again, I could just be talking out my ****. I really cant seem to put my finger on a cause for this, but the more I can eliminate, the closer I'll get i guess
tbonetony06
Apr 8, 2015 05:55 PM
Tommy-Law
Sep 4, 2013 06:17 PM
jcowan
Sep 14, 2009 01:51 AM
1stsporty
Ironhead
15
Jun 17, 2009 09:57 PM
damnitj
Exhaust System Topics
Mar 9, 2008 12:23 PM
