Good battery replacement?
Old Jun 8, 2013 | 09:08 PM
JaronB's Avatar
JaronB
Will going up to a 500 cca battery do anything bad to our bikes?? I know when I went from a 700 to a 850 cca on my SUV it made a world of difference, but that's a big motor and big starter. My bike has always seemed to turn over slow, but I think it's normal hearing everybody else's and it's never not started. If bumping up the cca's will make my bike turn over better I might just get a new battery.
Old Jun 8, 2013 | 09:14 PM
sonnydaze's Avatar
sonnydaze
its harder on ring gear and drive gear but those are wear parts any ways
Old Jun 8, 2013 | 09:28 PM
JaronB's Avatar
JaronB
What would be a max cca to not screw those up to fast??
Old Jun 8, 2013 | 10:11 PM
sonnydaze's Avatar
sonnydaze
your stock wires limit you more than your battery over 390 cca , so over that is over kill but is a 500 cca battery really 500cca ? the cca depends on how its tested and at what temp
Old Jun 8, 2013 | 11:34 PM
loopie's Avatar
loopie
theres a trick we use too do on some cars , run a 30 amp relay thru your starter curcit so your starter soleniod is getting a good current when you hit the start button, and yes size off leads do help with things,,,
Old Jun 9, 2013 | 12:33 AM
Gaffy52's Avatar
Gaffy52
Originally Posted by Gommee
Still running my 07 original battery, still going strong.
Me too - keep it on a battery tender all the time.
Old Jun 9, 2013 | 12:48 AM
Deuuuce's Avatar
Deuuuce
I'm amazed at the variance in the life of batteries. I don't mean the flukes lasting 1.5 - 2 years. I mean 5 to even 10 years. That is amazing.
Old Jun 9, 2013 | 01:55 AM
John_K's Avatar
John_K
8 years on my original so far and it's been killed at least twice. Once while cranking a stubborn engine, and once leaving the lights on.
Old Jun 9, 2013 | 02:55 AM
sonnydaze's Avatar
sonnydaze
I make my own wires out of 4 gauge 100 amp wire with soldered on ends , you can get it cheap at stereo stores . I also run a 100 amp ground wire straight to starter
Old Jun 9, 2013 | 04:33 AM
stilup's Avatar
stilup
http://www.batterymart.com/c-harley-...xd-1570cc.html
here's something to look at
