New 2013 Dyna Fat Bob
Old Jun 8, 2013 | 06:48 PM
bulldog82098's Avatar
bulldog82098
Default New 2013 Dyna Fat Bob
Just got a new Fat Bob! haas anyone drill out the rivets to remove the baffles on the stock mufflers and if so how do they sound. Trying to save some money!!!!!!
Old Jun 8, 2013 | 07:16 PM
Overlappinglittlepig's Avatar
I have some like new cycle shack slip ons with about 250 miles on them that I will sell for $150. They look exactly like the originals. Sound pretty good! Cycle shack mhd-348.
Old Jun 8, 2013 | 07:42 PM
xantasm's Avatar
xantasm
I have done the baffle removal to the stock cans when I still had my stock exhaust on my Fat Bob. It didn't sound bad but it didn't sound great either. Definitely doable as an interim till you decide on which exhaust you want long term.
You can also buy cycle shack baffles for pretty cheap that will go in the stock cans and bolt or rivet in place of the old ones. Or check out DK Customs thunder torque inserts or even do it yourself with a home made lollipop using some washers, bolts, and nuts from the hardware store.
Old Jun 8, 2013 | 07:58 PM
maddghost's Avatar
maddghost
You will need to get the cat out of the2/1 part as soon as you remove the slips. as for sound, at worse if you don't like it put your muffs back on with metal screws at least without the cat. I also have rush 1.75 slipons on a shelf going cheap.
Old Jun 8, 2013 | 08:03 PM
xantasm's Avatar
xantasm
You do not need to remove the cat if its just for increasing the desired sound. And the air flow restriction of the catalytic is not enough to improve performance by removing it. Removing it will add some to tone and volume of sound, that is it. Not worth the effort and I tried an earlier model FB head pipe with no catalytic and the difference was not worth the cost or the effort.
Old Jun 8, 2013 | 10:05 PM
bulldog82098
How much for the Rush Slip on's and how old are they?
Froggyfatbob
Apr 15, 2013 12:02 PM
blackout fxdf
Sep 11, 2012 05:36 PM
racertb
Jun 23, 2011 09:55 AM
grog_lives
Apr 1, 2011 08:40 AM
bjv11383
May 28, 2010 01:14 AM
