MY APE INSTALL
Old May 8, 2007 | 02:55 PM
  #71
jzarn786's Avatar
jzarn786
6th Gear
Default RE: Updated!
great post... i am looking to install 16 inch apes on my street bob. i have stock mini apes now and do you think that +6 will be long enough?
Old May 8, 2007 | 02:58 PM
  #72
HOGRIDA_06's Avatar
HOGRIDA_06
ORIGINAL: jzarn786
I was just about to send you the link to this thread. +6" should be plenty for the cables and 50" to 52" on the brake line.
Old May 9, 2007 | 01:30 AM
  #73
vjroadrat's Avatar
vjroadrat
2006 FXDBI
I installed Wild1 Chubbies 16" apes and 6" wastoo short. I went 10" over for clutch, throttle, idle.9would probably have worked fine too. Front brake was 52". Used the Ebony series from J&P. Bled it with a Mityvac. Worked great. I used the 8" wiring extension from J&P with the ends already installed. Makes it easy and fun. The connectors were a snap to take apart. There was plenty of slack.
Have ridden a few hundred miles with them and they are great! Only 6" higher but several inches wider.
Old Jun 25, 2007 | 10:06 PM
  #74
moose_tall_one's Avatar
moose_tall_one
Stage I
Default RE: MY APE INSTALL
Great article just wish I would have found this before I was half way thru my apes
I didn't know if there was going to be oil in the clutch cable cover now I know
The vacuum brake bleeder that they sell at Sears works great for bleeding brakes just hook it on the bleeder and keep the master cylinder full as you pump the vacuum pump.
Puttin16 inch apes on my 07 softail standard
Thanks
Old Aug 10, 2007 | 11:02 PM
  #75
Streetbob07's Avatar
Streetbob07
6th Gear
That is very helpful. I am going to do the changing of my bason My Street Bob hopefully this weekend. We'll se with the weather.
I get hot in sunny Florida. thanks for that info.
Old Aug 10, 2007 | 11:05 PM
  #76
Streetbob07
6th Gear
Great info Thanks. Changing my bar to 16" Z bars. Hopefully the Florida heat will cool off
some.
Old Aug 11, 2007 | 12:33 AM
  #77
efciv's Avatar
efciv
Great post. Look at all the replys. This really helped a lot of us. Thanx.
Old Aug 11, 2007 | 10:50 AM
  #78
PAPAFISH's Avatar
PAPAFISH
great job can't wait to do mine thanks
Old Jan 8, 2008 | 07:27 PM
  #79
amish's Avatar
amish
great step by step. now im that much more excited to get mine done. going for 16" apes 1 1/4 wild1 cubbys.
Im from IOWA as well what part u from bestofindica(waterloo here). again thanks for the step by step and now im ready to go
Old Jan 8, 2008 | 08:49 PM
  #80
chaelotte's Avatar
chaelotte
nice bob
