MY APE INSTALL
Old Jan 17, 2008 | 09:40 AM
  #91
Eddie4Harley's Avatar
Eddie4Harley
From: Holland (with the wooden shoes and windmills)
Default RE: MY APE INSTALL
Good Job, looks like you are a proffesional!
Old Jan 17, 2008 | 03:31 PM
  #92
Nostalgic07's Avatar
Nostalgic07
ORIGINAL: thebestofindica
I appreciate the positive comments. I started this thread over a year ago while putting bars on my fxdbi. I never ran across a thread that was comprehensive enough to make me feel real good about doing the work. I read hundreds and hundreds of threads and felt like I had enough information to do the job myself. It went very well and I saved a lot of money. I hope that this thread has provided the same for some of you.
Great post...I will be tackling this mod as soon as I get all the pieces... Got a question for you...When removing the trans. cover for the clutch cable...Is it recommended to get a new gasket?? I only have a few thousand miles, but I want to be prepared with everything I need before I rip it all apart and don't want any unexpected leaks...
Thanks.
[/align]
Old Jan 17, 2008 | 05:23 PM
  #93
joeld0803's Avatar
joeld0803
Damn nice post! Great detailed photo's. I did pretty much the same thing on my Street bob except I splised and soldered and heat shrinked everywire to add 8" to the length and left the fuel tank alone. I ran all the wires up thru the handle bars as well. It was alot of work and took approx 6 hours to complete the entire process but it was well worth it. The bike looks bigger just from the bars and they really fit the profile of the bike now other than the stock 10's mini apes. Since I did mine a buddy of mine bought all my stock hardware and I installed the stock tens on his Dyna street glide. I finished his in about 4 1/2 hours and now he is already saying he want to go and order the 13" apes. Geeze!!!!
Old Jan 19, 2008 | 10:35 PM
  #94
big_al's Avatar
big_al
great post, thank you for taking the time to do the post...
P.S. I wish it was a streetglide because I have no idea how to take the bars off....
Dont bash me guys about the manual...hehehe
Old Jan 20, 2008 | 07:37 AM
  #95
izzi's Avatar
izzi
hers's a cheat sheet.......
http://www.kenandjudy.us/Harley%20Pi...Bars/index.htm
Old Jan 20, 2008 | 07:52 AM
  #96
LtRex's Avatar
LtRex
Thebestofindica,
Great post! I know the trouble you went through to put this information up with pictures. It is a lot of work! Thanks!
As for the break line bleeding, I was taught a little trick that worked like magic! Once you have your fluid in, you can tell you have air in the line when the lever feels soft. Use a belt or piece of rope and pull the lever tightly and tie it down. In a couple hours the air has left the brake line and made it's way to the reservoir! I have used this method a couple times. It is easy and works great!
Old Jan 22, 2008 | 11:11 PM
  #97
Livi1215's Avatar
Livi1215
Thanks alot for this post. I ran into a little trouble doing my install and posted some pics on a new thread,tomorrow I should be able to finish up my install 16s on 07 SB. I will put the new pics under this thread. Thanks thebestofindica.
Old Jan 24, 2008 | 01:57 PM
  #98
hogster1961's Avatar
hogster1961
Excellent guide,one I shall certainly be referring back to![sm=goodidea.gif]
Old Jan 31, 2008 | 04:52 PM
  #99
njarvis1977's Avatar
njarvis1977
awesome thread iam in the middle of installing my 16" z-bars on my lowrider and this is helping alot
Old Jan 31, 2008 | 05:00 PM
  #100
Livi1215's Avatar
Livi1215
Some pics of mine thanks alot for this thread,bestofindica. 16s with 4in risers.
[IMG]local://upfiles/43000/4CAD0E662E27406B808FCEC742EC6277.jpg[/IMG]
