Question about useing oil
Old Jul 12, 2013 | 09:59 PM
KEYBEAR's Avatar
KEYBEAR
Default Question about useing oil
I have an 08 WideGlide bought it three weeks ago . It had 8,013 miles now 10,465 miles . It runs fine and had the oil changed when I bought it .
I check the oil every day I ride and it is always full . This week I took it to the dealer for a new clutch cable . When I got it back first thing I see is my gas is a lot less then it was ? I road 140 miles yesterday and this morning checked the oil (cold) and it was a little low ? This is the first time I have seen it low ? It was just off the add mark always in the middle until now .
What do you think happen ??
Old Jul 13, 2013 | 12:00 AM
Sharpie's Avatar
Sharpie
How much did you have to add to bring it back up to where it always was?
Old Jul 13, 2013 | 07:55 AM
rooti's Avatar
rooti
check it hot, cold will show less oil
Old Jul 13, 2013 | 08:08 AM
Iceman24's Avatar
Iceman24
Guessing your dealership,after cable install, took your bike for a nice "hard" ride...:O
As long as level's between full & low mark + nothing's leaking = you're fine.
Old Jul 13, 2013 | 08:22 AM
KEYBEAR's Avatar
KEYBEAR
I did,t add much 1/3 Qt. at most . I always check oil cold and look for it to be in the Mid range on the stick . I will look at it again this morning and see if it is ok .
I really wish the WideGlide had an oil tank .
Old Jul 13, 2013 | 08:34 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
It does have an oil tank. Below the transmission (just havin some fun, I know what you mean).
The newer configuration is actually a better location for the oil tank than the older setups or softails, because the oil is lower than the crankcase, so it won`t leak back down to the cases when the bike sits.
jclax01
Milwaukee Eight (M8)
15
Nov 6, 2016 09:42 AM
ms3300
Jun 5, 2011 12:50 AM
wils5150
Jun 2, 2010 08:34 PM
Mike in Oregon
Dec 11, 2009 07:52 AM
springerdave
Sep 11, 2007 09:05 PM
