some nicknack crap
Old Aug 30, 2013 | 07:35 PM
supermanotorious's Avatar
supermanotorious
thats exactly what I did, drilled from the back, perfect hole and pretty deep but couldn't keep drilling once it hit the extractor on the other side
Old Aug 31, 2013 | 09:34 AM
SquidHead's Avatar
SquidHead
Originally Posted by supermanotorious
I am ****ing besides myself, I installed the new spring washer EXACTLY as it is supposed to be and it still falls with vibration, I bought the Ryobi One right angle drill, got a perfect hole in the back of the broken bolt then tried an extractor and broke it, none of my titanium coated bits will drill through the broken extractors so I am done with the ****ing thing, it will just have 3 bolts to secure so I don't pull my ****ing beard out
Can't help with the stuck bolt, but I had the same problem with a peg. Try bending the spring washer a little more by putting in some channel lock pliers and gently squeeze until the bend is a little rounder. If that doesn't work, try tightening the snot out of the mount bolt and nut. Both methods have worked for me.
rydahog
Apr 24, 2026 02:55 AM
Boostedboxer04
Mar 12, 2018 05:04 AM
fafman
Apr 16, 2015 08:53 PM
roush360r
Apr 13, 2015 09:38 PM
black_iron
May 28, 2013 08:45 AM
