These boards?
Old Sep 27, 2013 | 07:13 PM
ResidentPirate's Avatar
ResidentPirate
Default These boards?
Anyone know what boards are pictured in this shot?
http://www.rolandsands.com/images/pr...ger-Seat-1.jpg
Old Sep 27, 2013 | 08:29 PM
VirtualNorm's Avatar
VirtualNorm
Look like Wyatt floorboards. I have a set on my 07. Easy install. Look good.
Old Sep 27, 2013 | 08:32 PM
Buckinfitch's Avatar
Buckinfitch
looks like a sheet of 4' x 8' plywood
Old Sep 27, 2013 | 08:46 PM
Road Burner's Avatar
Road Burner
Probably Performance Machine boards. Also owned by Roland Sands.
The brakes and bag latches are PM.
Old Sep 28, 2013 | 05:48 AM
AFMM3's Avatar
AFMM3
Looks like the stock footboards that come on any Electra-Glide.
Old Sep 28, 2013 | 10:13 PM
cycler's Avatar
cycler
They are performance machine http://www.performancemachine.com/mo...nd-levers.html Roland Sands doesn't own Performance Machine. His father owns Performance Machine.
Old Sep 30, 2013 | 12:14 PM
ResidentPirate
Thanks all for the responses - I'm particularly interested with the way they are mounted (assuming that those mounts are the ones that come with the boards) because they seem to run a bit higher than they normally do when mounted to a Dyna, and I'm looking to solve some clearance issues on a slammed bike I'm presently working on. Anyone have comments / opinions / insights on the mount job?
Old Sep 30, 2013 | 12:26 PM
cycler's Avatar
cycler
If you are going to mount them then use the Harley floor board kit. Then buy the kuryakyn floor board extension mounts that move the boards forward 1 inch and out one inch. But buy the ones meant to touring models. Then mount the boards onto the extension. that's what I did with my dyna
Old Sep 30, 2013 | 12:47 PM
203Cree's Avatar
203Cree
That would be the opposite of what he'd want to do. Moving them out an inch would absolutely kill what little lean angle he already has if he used the HD mounts.
Old Sep 30, 2013 | 01:35 PM
dirtdobber's Avatar
dirtdobber
I have looked at the photo several times. I even blew up the photo so I could see it better.
I do believe they are factory street glide floorboards and mounts. You know touring.
