Fuel Injector Cleaner?
Old Sep 30, 2013 | 07:17 AM
Warp Factor's Avatar
Warp Factor
Originally Posted by Markk9
You do understand that H-D uses a throttle body system, it's basically an updated carb. It's located in the same location.
Not really. H-D uses a sequential port injection system.
Old Sep 30, 2013 | 07:27 AM
Markk9's Avatar
Markk9
After more digging, your right.
Old Sep 30, 2013 | 07:43 AM
craig11dyna's Avatar
craig11dyna
Then I guess don't use the Techron fuel injector cleaner but Techron fuel system cleaner?
Old Sep 30, 2013 | 07:51 AM
1BRAVO9's Avatar
1BRAVO9
I alternate between seafoam, Marvel's, and STP. Is there the posibility of using this stuff too much?
Old Sep 30, 2013 | 07:59 AM
Markk9's Avatar
Markk9
I don't use any cleaner, just try and stick to a quality fuel, that has a good additive package.
Old Sep 30, 2013 | 08:02 AM
ynots's Avatar
ynots
I follow the instructions and do what the manufacturer recommends
Old Sep 30, 2013 | 08:08 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Since you ask. Think about it if you have ever cleaned a carb manually and what it takes to dissolve deposits. Will destroy o-rings and fuel socks at that level. At the level that is safe, doubt seriously it does anything. The only true way to clean injector would be to use an adapter in line. The only reason you should is you can see a drip after shut off inside throttle body. Any oxygen sensor late model bike compensates for any deposits.
yso191
Exhaust System Topics
16
Jun 3, 2013 08:46 AM
Rick341
Sep 4, 2012 07:11 PM
craigcrewcheif
Jul 24, 2008 09:42 PM
HOTLAP
Jun 30, 2007 09:08 PM
ggold
Dec 24, 2006 11:15 PM
