Front Wheel Removal
Old Oct 16, 2013 | 05:32 PM
ExDucRider's Avatar
ExDucRider
Default Front Wheel Removal
I'll be removing my front wheel on my 2013 Fat Bob.
This will be my first time of doing it on this bike.
I done many Japanese and Italian bikes in the past.
Just wanted to make that there are no surprises I am going to encounter.
So any tips would be greatly appreciated.
Also, I anything I should be aware of lifting the bike?
This will be my first time as well. I do have the yellow Craftsman Jack.
Btw, I was told by a service writer that I do not need to remove those front brake calipers. How is that possible? Hmmmm...
Anyone here done this before?
TIA
Old Oct 16, 2013 | 05:44 PM
Robbie13's Avatar
Robbie13
LOSER
I don't have a Fatbob and am not trying to be an ***, but do you have a service manual? The best investment you can buy for your bike! If for none other than the torque specs.
Old Oct 16, 2013 | 05:48 PM
QC's Avatar
QC
The wheel will slide out of the forks and calipers. This is a pretty straightforward operation. I have never had to remove the caliper to take off the front wheel. Have a shop manual handy for torque specs.
Use a tie down strap to keep the bike from doing a backflip off the jack when you remove the wheel. Usually won't happen if your balance point is ok, but better safe than sorry.
Old Oct 16, 2013 | 05:52 PM
ExDucRider's Avatar
ExDucRider
This is funny my local dealer just called me and said that my Service Manual just arrive. They said it was going to be in by Friday. I'm good.
Thank you!!!
Old Oct 16, 2013 | 06:04 PM
Robbie13's Avatar
Robbie13
LOSER
We weren't trying to be difficult. We will be glad to help you, but the manual is an awesome tool.
Old Oct 16, 2013 | 06:23 PM
ExDucRider's Avatar
ExDucRider
I know and that's why I did put an order. I was just anxious to install my new rotors on my wheels. I don't really need a service manual for this job, especially I already got all the torque specs from this forum the other day. I just wanted to make sure that removing the front wheel on the Harley is the same concept on all the bikes that I had in the past. It's all good.
Thanks!!!
Old Oct 16, 2013 | 06:41 PM
Kevin714's Avatar
Kevin714
Thanks!!!
Don't squeeze the front brake lever while you have your wheel off.
Someone said to strap your bike down so it wont tilt. I put a wood block under my rear tire to keep it from tipping backwards. While putting new tree's on my last Harley I had my bike tip. It was strapped down, but the jack tipped with it. Never fell over but got my attention.
Old Oct 16, 2013 | 08:20 PM
O-Town D's Avatar
O-Town D
"Btw, I was told by a service writer that I do not need to remove those calipers. How is that possible? Hmmmm..."
The 'chunky' wheel and tire on the FB won't slide out with the calipers in place - you have to remove at least one caliper and hang it out of the way before you can remove the wheel/tire.
Old Oct 17, 2013 | 01:41 AM
mirrmu's Avatar
mirrmu
H,
Yeah can take caliper off for ease of the process, probably good idea if you puttong on new rotors
Thanks
Mirrmu
Old Oct 17, 2013 | 09:31 AM
justintyme73's Avatar
justintyme73
Pay attention to those torque specs putting it back together, and that your torque wrench is correct. those Pinch bolts for the axle arent that tough, ask me how I know!
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
