Racetech spring, what's your experience?
Old Oct 20, 2013 | 01:23 PM
128auto's Avatar
128auto
Exclamation Racetech spring, what's your experience?
I am thinking to beef up my front suspension while changing fork oil. Got some amsoil medium weight, might as well upgrading the springs. Progressive or Racetech? I am not getting the gold valves at this moment, might try the springs/fork oil first and go from there. Perhaps some RSD adjustable fork caps. Thanks! Alex
Old Oct 20, 2013 | 01:30 PM
Juan L's Avatar
Juan L
Moderator
Great springs but after all they are just springs and what really helps is the valves....
Old Oct 20, 2013 | 03:38 PM
rooti's Avatar
rooti
There are some current threads going on in this dyna section on front end upgrades..a lot of info. The biggest change will be your ricor intimidators. The best consensus for springs with the ricors is a single rate spring (your stock spring is a progressive type)
Traxxion is the only one that makes single rate springs for the 49mm forks.
Here is the thread:
https://www.hdforums.com/forum/dyna-...n-upgrade.html
Old Oct 20, 2013 | 08:51 PM
parts eeter's Avatar
parts eeter
Progressive sells one size fits all springs, and Race Tech sells springs for your specific weight. That being said I couldnt tell ya which is best for you.
Old Oct 22, 2013 | 12:45 AM
oldlefty's Avatar
oldlefty
springs and valves all the way. it's a lot of work to pull your front end apart so in my opinion, do the valves also so you wont have to tear into it again. i have done the racetech springs and gold valves in a couple bikes and love the handling and ride.
Old Oct 30, 2013 | 04:16 PM
adam_hffh's Avatar
adam_hffh
racetech. progressive sucks. works makes a good spring kit as well but racetech is the best. the only one im considering over racetech is ohlins
Old Oct 30, 2013 | 08:58 PM
Warrior 72's Avatar
Warrior 72
I don't want to hijack a thread, but I will anyway. I'm in the process of ordering my Hagon Nitro shocks and have spent two days looking into the front forks and I'm still confused. I had a set of the Race tech Gold Emulators in two other bikes and they worked incredible, what makes the Ricors better? I'm planning on going with race tech VRod springs and either the Race Tech or Ricor valve, but all this talk about spacers is getting me worried that I will have to keep pulling this apart to get it right,
Old Oct 30, 2013 | 09:02 PM
SquidHead's Avatar
SquidHead
IMO...the best bang for the buck to improve your front end is going to be Ricor Intiminators with #10 Amsoil.
I'm still tweaking the right single rate springs from Traxxion for my ride, but honestly, you could drop in the Intiminators with that #10 Amsoil and be shocked by improved handling. Add the RSD or Speed Merchant adjusters and you can change the ride feel on the fly...even with stock springs.
izzyryder and I are both working on the Traxxion single rate springs with the Intiminators. If you're interested, his thread is here: https://www.hdforums.com/forum/dyna-...e-springs.html
Old Oct 30, 2013 | 09:11 PM
Warrior 72's Avatar
Warrior 72
Thanks for the link to that thread, it looks like I have a lot more reading to do.
Old Oct 30, 2013 | 10:01 PM
DynamicDyna's Avatar
DynamicDyna
Former Sponsor
We have a fully adjustable cartridge kit that is available for custom applications. We are currently working on making it available for immediate delivery. These are the best solution for conventional 39 and 49mm front ends. Next best thing is inverted forks. They come with compression rebound and preload adjustments. And are supplied with new fork caps that have all adjustment screws built in to the cap. I will post pics as soon as possible.
