Idle
Old Oct 24, 2013 | 12:22 AM
bezzeghdenes's Avatar
bezzeghdenes
Default Idle
I have a 2007 Low Rider with injectors. After a run always stop idle.
Any idea? Thanks!
Old Oct 24, 2013 | 09:36 AM
KEYBEAR's Avatar
KEYBEAR
A little more info is needed ? At this time no one can answer as no question has been ask ? All motorcycle run idle and at some point stop .
Old Oct 24, 2013 | 10:10 AM
SLV's Avatar
SLV
Any idea? Thanks!
Szia Bezzegh,
I think the problem is in the fuel tank.
Check that the tank vent-hose is not pinched or obstructed.
Try loosening your fuel cap to see if the bike will idle.
Check your fuel filter (replace it.)
Usually if your bike won't idle, especially after running, it is fuel/air related. The best guess is that your bike developes a vacuum in the tank and the fuel can't flow to the injectors.
Old Oct 24, 2013 | 11:23 AM
FreddyP's Avatar
FreddyP
My 03 EG has EFI. When the IAC needs to be cleaned the system tries to set the idle point so low it will often stumble and die after the bike has warmed up. A little carb cleaner sprayed in the IAC hole, cycle the bike off and on, and it normally clears the problem. Just something to look at if you have EFI :-)
Old Oct 24, 2013 | 11:46 AM
nevil's Avatar
nevil
I agree that it's a dirty IAC. Although probably better to use throttle body cleaner if you can. It may not make a difference but I have read that carb cleaner is not the best choice. Could be BS but it can't hurt to use the product that's made for EFI.
DBurns INC
Feb 12, 2019 09:42 AM
wiscdyna
Jul 14, 2012 05:35 PM
rhinoevans
Feb 7, 2012 11:57 AM
nova2sportster
Aug 31, 2011 08:37 PM
glide2005
May 25, 2009 04:06 PM
