DEUCE wheel upgrade and S&S filter
Old Oct 30, 2013 | 06:46 AM
oakspeed's Avatar
oakspeed
Default DEUCE wheel upgrade and S&S filter
started my winter mods.
progessive springs, deuce rear wheel, and S&S air filter kit.
SE cans on stock headers till i decide what pipes to run with.
got fed up with the big shots.
front brake upgrade next.
Old Oct 30, 2013 | 06:59 AM
mojo6677's Avatar
mojo6677
Do you still have the big shots? If so you willing to sell them?
Old Oct 30, 2013 | 07:13 AM
oakspeed's Avatar
oakspeed
i would, but im based in the UK.
it would cost more than they are worth to post them across the pond.
Old Oct 30, 2013 | 10:38 AM
Sharkman73's Avatar
Sharkman73
Considering doing the S&S air cleaner kit myself....do you have a part # you used?
Thanks
Old Oct 30, 2013 | 11:19 AM
128auto's Avatar
128auto
Is the Deuce rear wheel straight bolt on?
Old Oct 30, 2013 | 12:27 PM
oakspeed's Avatar
oakspeed
Thanks
the part number was 17-0450.
yes and no.
if you use the old painted deuce wheel, you need to have the centre bored out to 33mm to accommodate the larger diameter spacer used in the wheel fitting kit. if you look up harleys own instruction leaflet, J04057, it will tell you what kit you need for your particular bike.
if its a newer chrome wheel, its a straight bolt on job, with the appropriate wheel fitting kit for your bike. i used the wide glides rear disk and pulley, all lines up. no need for spacers on the rear disc etc.
no more rusty/wobbly spokes.
pm me if you need more info.
Old Oct 30, 2013 | 12:33 PM
128auto's Avatar
128auto
Thanks! I am told the newer Deuce wheel is straight bolt on. When you say newer, like 06 up? Good looking wheel, always wanted one!
yes and no.
Old Oct 30, 2013 | 01:08 PM
oakspeed's Avatar
oakspeed
all i know is that if the wheel is a chrome one from the factory, it has allready been drilled large enough to bolt into late model dynas with 25mm bearings. not sure of the exact year they swapped over.
Old Oct 30, 2013 | 01:16 PM
128auto's Avatar
128auto
Thank you! I found one, it is 06 up straight bolt on.
http://www.shopronniesharleydavidson...2&ez=&pos=1#/0
Old Oct 30, 2013 | 01:31 PM
Sharkman73's Avatar
Sharkman73
Thanks! I've had trouble trying to figure out which part # would work on my '12 96". Looks like your bike is an '11? If so, the same part # should apply to my bike as well.
yes and no.
