Bar change question
Old Nov 19, 2013 | 03:51 PM
SLV's Avatar
SLV
You guys are awesome! Thanks for all the notes. I found the plastic cover too. This will help if I need to stow any extra wire.
No cable replacement planned. The clutch cable will be a bit long, but I have a plan to strategically re-route sone of it.
Also, I found this series of videos that goes through the entire process. It's a home made video, but extremely detailed.
Thanks again guys.
Old Nov 19, 2013 | 05:13 PM
JRK5892's Avatar
JRK5892
sorry late to the party, but i like to unplug them under the neck, wire it all on the bench and then plug it all in... sorry to be so late, if you have any questions i think you have my cell feel free to call
Old Nov 19, 2013 | 05:20 PM
Robbie13's Avatar
Robbie13
LOSER
SLV what are you doing now??
Old Nov 19, 2013 | 05:46 PM
JRK5892's Avatar
JRK5892
T bars and fairing i am guessing
Old Nov 19, 2013 | 05:50 PM
Robbie13's Avatar
Robbie13
LOSER
Oh, ok. Didn't see that part.
Old Nov 19, 2013 | 06:27 PM
SLV's Avatar
SLV
Close. MX bars, 11" risers, fairing.
Joe,
Thanks for the tip. I have the means and will test the wiring befor finishing up.
Old Nov 21, 2013 | 03:29 PM
SLV's Avatar
SLV
A little update.
Not a task for an hour or two. It would have been if I had chosen normal 1" or. 1 1/4" bars. Unfortunately, MX bars are 7/8" OD at the grip area. As a result, the wire bundles don't fit in the bars without taking all the black insulation/shrink-wrap off.
Also, the new model waterproof connectors, although small, don't fit. I couldn't get them apart, so I cut-and-spliced. No worries though, I was an electronics engineer at one point and consider this one of my few skills.
Then, I blew a fuse and had to go get a new one.
Everything is working, but I need to get the throttle back together, then tuck all the wires and route sone cables.
Superdog3:16
2018+ Softail Models
Jun 15, 2019 08:01 PM
M4i2k2e2
Electrical/Lighting/Alarm
Apr 14, 2019 08:27 PM
justintyme73
Oct 19, 2013 10:31 AM
cnd_rocker
Feb 27, 2009 10:15 PM
fatboyinaz
Sep 7, 2008 05:31 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
