V Rod engine
Old Dec 6, 2013 | 02:23 PM
  #31
brandon95354's Avatar
brandon95354
Originally Posted by Spanners39
Well...I would rather ride one than any of the SOA lookalike air-cooled bikes that seem to be cluttering up the place
The valve adjustment thing is a non-issue for me as I have yet to come across a V Rod that actually needs the valves re-shimmed....that is the joy of shimmed valves, they last for like...ever.
I think a Fatbob with a V Rod motor would sell like hot cakes!
I also think that this scenario is quite likely to happen and sooner than you think and it will sit between Sporties and Dynas in a model range of its own..."V Glides"
+1 on those lame dynas with fairings and long shocks, im surprised when you buy a 1/4 fairing it doesnt come with a SOA patch. i clown those guys every time i ride by them, about the lamest style of bike i have ever seen. thank god most of them are in CA hopefully they get wiped out from splitting lanes....idiots, this forum even has a lame thread club style dynas. the thread should be called d*ck heads on dynas.
Old Dec 6, 2013 | 02:30 PM
  #32
Cascade's Avatar
Cascade
Nope,
Don't like the sound of that motor.
Old Dec 6, 2013 | 02:34 PM
  #33
Reindeer's Avatar
Reindeer
Originally Posted by Two Lane Tramp
If Harley installed a water cooled V Rod engine in a Dyna frame, would you buy it?
No. I'm sure there's a market for a more comfortable and practical version of the V Rod but its not for me. I like my air cooled Super Glide just fine, thank you.
Old Dec 6, 2013 | 02:51 PM
  #34
oakspeed's Avatar
oakspeed
i remember reading in one of the Uk comics, that a guy put a v-rod motor into a bagger. looked pretty good from what i can remember.
Old Dec 6, 2013 | 02:53 PM
  #35
Sharkman73's Avatar
Sharkman73
Originally Posted by Warp Factor
With 120 hp, it should generate plenty of rear wheel torque, which is what moves the bike.
It generates it's torque peak at a higher rpm, which means it can be geared down more (the force is multiplied) before it reaches the rear wheel.
The current VROD engine generates about 83.4 ft/lb of torque at the crank...that's putting about 73 or 74 to the rear wheel....which is less than a bone stock 96" TC. Adequate...maybe because it has a lot more hp. Problem is like you said it makes tq at a much higher rpm, not at low rpms like a TC.
Good horsepower numbers don't mean good tq at all. Think of a metric sport bike...they make awesome hp, but shitty torque. The Revolution engine has similar hp to tq ratio characteristics as a sport bike, but torque is helped out by the fact that it's a v-twin instead of an inline.
If they were going to put a Revolution type engine in a Dyna or touring bike...it's going to have to have more displacement & get tq numbers up around 100 at the rear wheel to be worth while.
Horse power is good for bragging rights on the dyno...torque gets the job done. I want that torque that comes on at very low rpms without having to wind out the engine to get the power out of it. Don't get me wrong, the current 1250 Revolution engine is a great engine, but it's a completely different feel than a TC and lacks torque. Increase the displacement to 1600 or 1700 & you move toward solving that problem.
Old Dec 6, 2013 | 03:42 PM
  #36
SLV's Avatar
SLV
Huh? The math doesn't support this. If you geared it down enough to provide 100ft/lbs of torque, you would need an eight speed transmission. By the time you reached fifth or sixth gear, you would already counteract the advantages gained from the gear-down.
The Revolution solution is a heavier flywheel and a longer stroke; but the engine wasn't designed for it, and you end up with yet another compromise (which the TC motor has been doing since it became a 96" motor.)
More than likely, a new WC motor for the Dyna/bagger line-up will be entirely new.
Old Dec 6, 2013 | 08:47 PM
  #37
Two Lane Tramp's Avatar
Two Lane Tramp
This has been an interesting read for me. So many different opinions. It's hard for me to imagine making the V rod motor into the style bike that I like. I just always thought it was a shame that they put that much technology into a bike that is so uncomfortable to ride. But then maybe if I were younger I would like the riding position and handling challenges.
Old Dec 6, 2013 | 09:53 PM
  #38
Chasespeed's Avatar
Chasespeed
The worst thing about the Vrod, is the forwards. A couple models had Mids, and there are aftermarket mid controls available, that are closer ion location to a typical harley with mids.....
Chase
Old Dec 7, 2013 | 10:54 AM
  #39
emerican19's Avatar
emerican19
U mad bro?
Old Dec 7, 2013 | 11:43 AM
  #40
Warp Factor's Avatar
Warp Factor
Sorry, but it sounds like a couple of you haven't thought the "torque" thing all the way through. There are common misunderstandings about torque, horsepower, and what moves a vehicle down the road.
Let's take a 103" with 92 torque at 3000 rpm, and compare it to a V-Rod with 83 torque at 6750 rpm.
Since the V-Rod is turning roughly twice the rpm at it's torque peak, you can have twice the gear reduction between the engine and the rear wheel at the same vehicle speed. Twice the gear reduction means that the rear-wheel torque is doubled. The amount of rear-wheel torque (twisting force) is what's responsible for accelerating the bike, all other things being equal, and that's why a bike accelerates much faster in 1st gear than it does in 3rd. 1st has a larger gear reduction.
So the bottom line is that a bike with the V-Rod engine will deliver about twice as much torque to the rear wheel, compared to the 103, if both bikes are going down the road at the same speed, and both engines are running at their peak-torque rpm.
Engine torque by itself doesn't mean much, until you factor in the rpm where it makes that torque. Once you do that, by jimminy , you're suddenly talking about horsepower. That's why horsepower is the common measure of how much "work" an engine can do, and why a tiny engine with very low torque, screaming at 15000 rpm, can leave a Harley in the dust, even if both bikes weighed the same.
To put it a different way: If an engine made peak torque at 10 rpm, it would need 27,600 foot pounds of torque to make the same power as the Harley 103 does at 3000 rpm.
