Oops. Where does this wire go?
Old Dec 19, 2013 | 02:21 PM
TheePaulieP's Avatar
TheePaulieP
Default Oops. Where does this wire go?
I was installing my PCV on my 2007 Street Bob and as I was putting it all back together I noticed these two little suckers hanging free. They are the wires that come off of my rear O2 Sensor. Not very handy when it comes to electrical and I cant find anything under the seat or in reach of the wires that seem to be missing their plug.
Pic is attached.
Old Dec 19, 2013 | 02:57 PM
spyderwebb's Avatar
spyderwebb
If that is the rear 02 sensor harness then it looks like it is missing the connector housing that went around it, which you should have just used the supplied "sensor eliminator" to plug [plug would go on the ECU side), this cable to the pipe would then just be left unconnected.
On the PCV the front and rear sensors are not used (hence these systems are referred to as "open loop").
It looks like you might have pulled the cable right out of the connector housing though.
Old Dec 19, 2013 | 04:13 PM
TheePaulieP
So if I just slap some electrical tape around the two wires it wont be an issue because of the PCV I installed?
Thanks!
Old Dec 19, 2013 | 04:58 PM
spyderwebb's Avatar
spyderwebb
Sounds right.
Old Dec 19, 2013 | 07:15 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
I'd just put a butt connector on each one of the bare wires, could go as far coating the wires with pet. jelly to keep corrosion at bay.
Rackoon
Electrical/Lighting/Alarm
May 28, 2019 11:06 AM
illlogic187
Apr 23, 2012 11:24 AM
SixSixRider
Sep 18, 2009 08:41 PM
tk353
Jun 20, 2009 09:05 PM
Scubadog
Apr 10, 2009 08:18 AM
