harley timing
Old Dec 31, 2013 | 11:55 PM
07 dyna man's Avatar
07 dyna man
Default harley timing
does anyone know what the the total ignition timing and what rpm its at full advance
Old Jan 1, 2014 | 01:02 AM
latrobedyna's Avatar
latrobedyna
Happy New Years up there in the ice box of Pa. you mean in the stock config or with what ever tune you are using?
Old Jan 1, 2014 | 05:03 AM
Foxster's Avatar
Foxster
Stage-1 timing table looks like this...
Old Jan 1, 2014 | 10:54 AM
07 dyna man
im taking it that stage 1 is different than stock timing im trying to find out what stock timing is
Old Jan 1, 2014 | 11:01 AM
Foxster's Avatar
Foxster
That's trickier because the SEPST doesn't let you download the stock map. Been asked a few times before and for the fuel too, not seen an answer.
Old Jan 1, 2014 | 09:03 PM
nevil's Avatar
nevil
Your best bet for finding the stock timing might be with the service dept. at a dealer.
Old Jan 1, 2014 | 09:38 PM
07 dyna man
yeah I was thinking about that .but since I moved to north east pa. the nearest dealer is an hour away I don't really want to call them I would rather ask them in person
Old Jan 1, 2014 | 10:09 PM
TonyGinFla's Avatar
TonyGinFla
I don't have a manual for a 2007, but the 2006 manual says "Ignition timing is controlled by the ICM based on input from the MAP sensor and Crank Position sensor. No ignition timing adjustment is required, or possible". I can't find any reference as to what the standard should be.
hdrider.tx
Touring Parts
Sep 30, 2022 08:35 AM
Scudda
EVO
Nov 27, 2012 02:11 PM
hdrider.tx
Softail Parts
Jan 12, 2010 08:27 AM
hernan
Jan 3, 2008 11:12 AM
bluebagger06
Jul 16, 2007 07:59 PM
