Can I remove this bracket?
Old Jan 4, 2014 | 03:12 PM
monster715's Avatar
monster715
I wish I wouldn't have read this thread.... Now I just realized I never took mine off either... It's already bugging me
Old Jan 4, 2014 | 05:31 PM
arkstreetbob's Avatar
arkstreetbob
With my short exhaust It was not used. Could not get to the bolts holding it on so painted it black. Went to Supertrapp Supermeg 2:1 exhaust and it uses the bracket. Paint it black and ride.
Old Jan 4, 2014 | 05:38 PM
rh8234's Avatar
rh8234
Okay - I spent an hour in the garage and got two of the three bolts out. The third one requires a special wrench. T-27 bit and I used a dremmel cut off wheel to shorten the bit and am gluing (with JB Weld) the shorten Torx bit into a 1/4 inch box wrench. When the JB Weld sets, the wrench should be thin enough to fit between the bracket and frame. I will report tomorrow how it goes. If it works, I will be happy to mail the home-made T-27 / 1/4"wrench to anyone else that wants to remove the bracket. All I will ask is that when you are done with it - mail it on to the next guy that wants to use it.
Old Jan 4, 2014 | 07:14 PM
ynots's Avatar
ynots
your probably the only one who will ever notice it. if you take it off be sure and return the case screws
Old Jan 4, 2014 | 08:32 PM
steve5109's Avatar
steve5109
I also got 2 of the bolts out and couldn't get out the last one. Didn't know they sold the tool I might have to look into that.
Old Jan 4, 2014 | 10:24 PM
rooti's Avatar
rooti
Ya most shops just cut the bracket and it looks like ****. I removed mine and it looks clean.
Old Jan 5, 2014 | 06:59 AM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
Originally Posted by 99%r
Thanks. I will remove mine.
Just to be on the safe side I would heat the area up with a hair dryer first. Those damn torque screws can be a pain.
Old Jan 5, 2014 | 07:11 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Here's a link to the special tool:
http://www.ntxtools.com/network-tool.../KAS-6538.html
Old Jan 5, 2014 | 08:09 AM
tomt's Avatar
tomt
I took that bracket off too. I took off what bolts I could reach. Then I tapped the bracket back and forth with a hammer till the bolt got loose and took it out with a pair of pliers. No special tools.
Old Jan 5, 2014 | 11:08 AM
rh8234's Avatar
rh8234
I got my bracket off this morning. The tool I made worked only well enough to back the bolt our about 1/4 inch. I used a hacksaw blade (no handle because it would not fit in there) to cut the head off the bolt and the bracket came right off.
