Started my 106 build
Old Jan 21, 2014 | 12:39 PM
schlacker's Avatar
schlacker
Can't wait to see finished pics!
Old Jan 21, 2014 | 03:59 PM
dirtdobber's Avatar
dirtdobber
Getting 100 TQ at 3,000 from a 106 is pretty normal with the head work being done. Depending on what head work your doing.
Ours is a little over that, 102, we are using the SS585 easy start cams.
All I can say is your gonna really love it. They are a blast to ride.
Old Jan 21, 2014 | 04:27 PM
nathanw's Avatar
nathanw
No need to run the plate, it's purely an option as it works perfectly fine with the stocker according to Randy at Hyperformance.
I don't claim to be an expert, but I've talked to a lot of people and read a ton on this stuff ( much of it from people that I would consider experts ) in the past few months and the SE just isn't needed or worth the $$$. Many will say the DT isn't needed either, but it's the better option of the two.
Originally Posted by HD Bobber
I suck at math, but $364.15 (from new castle hd) for new plate & pump are far less than $439 for pump & $319 for the plate from R&R Cycles. I'm sure the DT is much better than the SE, but the $$$$ difference is huge .
Old Jan 21, 2014 | 05:17 PM
johnnyjellybean's Avatar
johnnyjellybean
At 40% off all parts and free machining, I'm buying what ever my bud Randy says. Between that and doing the assembly myself, the whole thing is costing me $2800. I'll take the extra piece of mind that the SE plate and pump gives for that price thank you.
PS: the Randy I'm talking about builds 50+ motors a year and has been doing so for a very long time. I don't question anything he says. I'll post dyno results in May.
Old Jan 21, 2014 | 05:33 PM
HD Pilot's Avatar
HD Pilot
You are going to do a crank run-out check right?
Old Jan 21, 2014 | 05:44 PM
johnnyjellybean
Just read a bit about the Thayer pump. It looks great but I'd never even consider putting out that kind of coin for an oil pump for this build. I paid way less for the pump AND plate.
Old Jan 21, 2014 | 06:37 PM
HD Bobber's Avatar
HD Bobber
Very interested to see the numbers when you get here dynoed. Our build will be very similar. I'm running gear drive 585's, head work, roller rockers. My TB will be stock for the time being though.
Old Jan 22, 2014 | 06:05 AM
nathanw's Avatar
nathanw
Just offering you an option that you or your builder may not have thought/know of, that is all. I'm sure your build with the SE will be more than OK.
Enjoy.
Old Jan 22, 2014 | 07:49 AM
johnnyjellybean
Another known fact is that stock pumps and oil plates are notorious for low pressure at idle and if I were even to consider using a stock plate, it would be with a different pressure valve spring or at least a shim.
Old Jan 22, 2014 | 10:15 AM
HD Bobber's Avatar
HD Bobber
Smile
That's why I got the Baisly plunger & Baisly LMR-2 spring for the cure.
http://www.zippersperformance.com/ba...s-plunger.html
