Started my 106 build
Old Feb 2, 2014 | 10:49 AM
  #31
HD Bobber's Avatar
HD Bobber
The gauge I got was about $60 to check my run out. Once you are already there, in my own opinion, it should be checked. It's good to plan ahead and know so that you don't build everything then year or two it's got to be torn back down due to an issue.
Old Feb 2, 2014 | 11:17 AM
  #32
nathanw's Avatar
nathanw
I find it interesting that crank runout is internet hype but oil pumps and pressure springs are "known issues" that must be addressed.
Originally Posted by johnnyjellybean
What's so important about the crank runout? It's only an issue if it's out of spec. Did you bother asking if my cam/crankcase clearances were in spec? Did you ask how much I had to clearance the upper rocker boxes? Perfect example of internet hype. My crank runout measured less than .002. If it would have been out of wack , I would have said so. What you might consider important, to me is just run of the mill stuff. Let me know if there are any other tolerances you wish to know aside from "the sky is falling" crank runout on 07 + twin cams
Old Feb 2, 2014 | 11:26 AM
  #33
fat bastard 68's Avatar
fat bastard 68
Exactly, that's what I'm doing, planning ahead
BTW Hows your build coming along and when're you going to do a thread with lots of pics???????
Old Feb 2, 2014 | 12:04 PM
  #34
HD Bobber's Avatar
HD Bobber
Yup just double check everything and take your time.
I'll do a thread once she fires......last Tuesday she was ready to fire. Three times I tried and the fourth the fuel pump didn't prime any more when I tried to turn her on! What are the F&&king odds! Needless to say I'm pissed! I checked everything, so I ordered a new pump, fuel filter(since I'm in there), and top gasket. About $160 later parts should arrive by next Friday.
........hope she fires up!
Old Feb 2, 2014 | 12:12 PM
  #35
HD Bobber's Avatar
HD Bobber
I'm not sure if it was already on its way out last riding season, or if keeping very little gas in it the whole winter in my cold garage effected it, or ...... I don't know what else.
Rumblin
Engine Mechanical Topics
22
Aug 7, 2015 09:05 AM
Crusty369
Nov 8, 2013 12:55 PM
480Ruger
Exhaust System Topics
Jan 10, 2013 09:50 PM
Captain Black
Screamin Eagle CVO Models
Apr 13, 2012 05:09 AM
GasCan
Feb 20, 2009 08:09 PM
