97 wide glide speedo/odo stopped working
Old Jan 19, 2014 | 01:39 PM
97FXDWG808's Avatar
97FXDWG808
Stage II
Default 97 wide glide speedo/odo stopped working
Hi guys, I've searched this site before posting to narrow down possible culprits as to why my speedo/odometer quit working on my 97 fxdwg with orig speedometer.
Two weeks ago I was riding on the hwy at about 70mph when I looked down at the exact time the speedo dropped to zero and the odo (digital) stopped displaying mileage. It hasn't worked since. The speedo/odo still light up with the backlights but no mileage is displayed.
After reading these forums it appeared as though I needed a new VSS which I've swapped out and it didn't solve it.
I've checked the fuses and they all function. There are four metal capped fuses but not sure if any have to do with the functionality of the speedo and odo.
Other than having to buy a new speedo are there any other areas to look at to fix? I've pulled the speedo and checked the connections but they seem fine.
Any tips will be greatly appreciated as new speedos are $500. Harley doesn't even make mine anymore as it's an obsolete part but I've found a dealer that has one left in stock. I really don't want to go aftermarket because I like the look of the original. Another question I have is if I did spring for the new speedo, will it display 0 miles or the current mileage on my bike (≈11,000)
Old Jan 19, 2014 | 01:43 PM
Robtarra39's Avatar
Robtarra39
Not sure what a VSS is , but did you check your speed sensor, sometimes a cleaning will solve it, as for new speedo it will say zero miles but the dealer or HD can program the correct mileage for you, you could also look for one on Ebay for a used one with mileage that is close to yours
Old Jan 19, 2014 | 02:00 PM
lownslow's Avatar
lownslow
2 years ago, my odometer display was fading away, ('98 wide glide), speedo worked ok. I sent it back to HD, they fixed it and programmed in the current mileage so it's close. $325.00, and I did the R&R. Not too hard really. Been working fine since. Stuff is electronic and computerized now so maybe it's nothing mechanical.
Old Jan 19, 2014 | 04:31 PM
1999 Wide Glide's Avatar
1999 Wide Glide
OP,
I would have your speed sensor checked first. About a year ago I had the same thing happen on my 99 WG. I assumed that it was the speedo and immediately popped for a new Autometer Speedo/tach combo. If you go this route make sure that they set the mileage before they ship it. The dealership cannot do this they have to be set from the factory. I learned this the hard way. I had to take mine back off and send it back to set the odometer.
In my case it was actually the speed sensor that had been smoked by a short in the harness. Fixed the harness and replaced the speed sensor all is good to go now.
Old Jan 19, 2014 | 05:44 PM
97FXDWG808's Avatar
97FXDWG808
Stage II
VSS = vehicle speed sensor
Yes, first tried a cleaning as it had some metal shavings on it but not too bad. After that didn't work I bought a new one and still no dice.
bigsteve799
Sep 21, 2023 12:05 PM
NickSchoff
EVO
Sep 19, 2023 11:39 AM
TSheff
Apr 22, 2014 06:56 PM
THEXFILES
Sep 12, 2013 12:29 AM
whitedaddy
Jul 14, 2007 02:27 AM
