Vibra-Technics motor mount install
Old Mar 19, 2015 | 05:44 AM
  #261
Portoz's Avatar
Portoz
Where can i purchase a vibra technic? And how much are they selling for?
http://www.vibra-technics.com/harley...t_engine_mount
Old Mar 20, 2015 | 03:02 PM
  #262
El Chiguete's Avatar
El Chiguete
Actually they have a separate website just for the HD mounts and you can purchase and see the models for early Dynas, late Dynas, FLH and even FXR models! Check it out http://www.predatorvcs.com/harley_davidson
Last month I had driving issues coming back home from a trip and it looks like it has a bad rear OEM mount that after reading this thread looks like the desing of the front mount makes tha rear go bad more oftend... now I'm REALLY thinking on getting this product!
Old Mar 25, 2015 | 12:49 AM
  #263
El Chiguete
Anyone has a contact numer or email besides the website?
Old Mar 25, 2015 | 02:38 AM
  #264
Tnbrit's Avatar
Tnbrit
Default Contact
Below is the Contact details from the Website.
If calling from the US: 011 44 1536 202789
website-enquiry@vibra-technics.co.uk
Cheers,Graham.
Old Mar 25, 2015 | 02:42 PM
  #265
d1hojo07's Avatar
d1hojo07
This company is so firkin fantastic to deal with, it is totally amazing. I think it's been over a year since I bought the first mount. I couldn't get the mount to line up right so they sent me a different one. It was better but still wouldn't line up right. Well, life happened and only got about 800 miles on the bike and it's been down for over a year. Phil still worked with me to get it straightened out. After all this, it turned out to be Harleys quality control.- or lack of it- The front frame mount should be right at 45 degrees. Mine was 50 degrees. So, with a little help from a large pipe wrench and a short jack, it is now at 45 degrees. HA. I had put the other mount on a friends bike and it worked great. He decided he wanted to keep it since after about 3000 miles the oem mount was already junk. I ordered another mount and it showed up a day early. It fits great so far. Now, if I can get the bike running soon I think I will be very happy.
Old Mar 25, 2015 | 02:47 PM
  #266
d1hojo07's Avatar
d1hojo07
I wanted to put these pics on the thread but didn't work.
Attached Thumbnails Vibra-Technics motor mount install-dsc03495.jpg   Vibra-Technics motor mount install-dsc03498.jpg
Old Mar 26, 2015 | 01:36 PM
  #267
El Chiguete
Originally Posted by d1hojo07
... The front frame mount should be right at 45 degrees. Mine was 50 degrees. So, with a little help from a large pipe wrench and a short jack, it is now at 45 degrees. ...
Is this also true for Evo frames?
Also, if one uses shorter shocks should you take that in account?
Old Mar 26, 2015 | 08:22 PM
  #268
dynawg1's Avatar
dynawg1
emailed them through their website last night with a few questions. Had a reply when I woke up this morning. Great responsiveness. Phil said that they are currently running behind due to high demand and it would take 10 days to receive a Predator. Will ship FedEx Priority to me. Ordered one this morning.
Old Mar 26, 2015 | 09:01 PM
  #269
mattVA's Avatar
mattVA
Can you elaborate what was wrong and what you did to fix? Not sure I follow.
Old Mar 31, 2015 | 05:53 PM
  #270
d1hojo07's Avatar
d1hojo07
The part of the frame where the mount bolts to should be at 45 degrees. Mine was 50 degrees. I had to take a big pipe wrench and a short jack and push it up to get the 45 degrees. I had the motor out so it was pretty easy.
The problem was that when I would lower the motor the mount block wouldn't line up with the frame mount. It would end up forcing the center bolt back towards the motor and kind of bind it up. I was still getting a lot of vibes through the frame. I think this is a problem with the stock mounts too. I think it's why some people have said that when they let the motor down and there is larger gap at the top or bottom. It amazed me what a little 5 degrees would do to screw things up. I know the preditor mount is going to be great. I think it will outlast the stock crap 10 times over. And the built in stabilizer is just an added plus. You can put a truetrack or sputhe on the front, but the crappy stock mount is still going to wear out. I wish they would come out with a rear mount also. This is just how I see it and feel about it. Tim.
