Sick of this red indicator light
Old Mar 2, 2014 | 08:44 PM
Reaper7534's Avatar
Reaper7534
Default Sick of this red indicator light
2013 Dyna SuperGlide
I have a red indicator light on my speedo after I installed Radiantz LED lighting all around my bike. Everything functions properly, just get aggravated seeing that light go off and on intermittently.
I know this is related to adding the LED's since they don't draw as much as the standard bulbs. Will adding a stabilizer fix this problem and which one do I need.
As I said....signals all work, flashing at normal rates, signal indicator is also normal. Been dealing with it for 6 months, gotta fix it.
Thanks
Tim
Old Mar 2, 2014 | 08:54 PM
dirtdobber's Avatar
dirtdobber
Have you checked for codes?
http://www.customdynamics.com/led_mo...hting_faqs.htm
Old Mar 2, 2014 | 08:57 PM
Iceman24's Avatar
Iceman24
Yes, it's because of the low draw for your added LED's and the bike will continue throwing this code unless you add the load equalizer. Radiantz should have one they can recommend, or go to Custom Dynamics.
Reaper7534's Avatar
Reaper7534
Originally Posted by dirtdobber
I " think " I have, but honestly don't remember. The Power Commander Vision is able to see codes, right ?
Old Mar 2, 2014 | 09:02 PM
Reaper7534's Avatar
Reaper7534
wish I thought of this when I just ordered my accent lighting from CD. Guess gives me a reason to ride over there, only 75 miles away
Old Mar 6, 2014 | 02:22 AM
HooliganCycles's Avatar
HooliganCycles
You have trouble codes
Old Mar 6, 2014 | 05:44 AM
1HD1C's Avatar
1HD1C
its from the radiantz, contact them and i think they will send you out a resistor to fix the light code..
i have seen it listed on another site
Old Mar 6, 2014 | 07:39 AM
SLV's Avatar
SLV
Your 2013 CanBUS wired system will operate LED signals and taillights, but the signal indicators on the dash will simply flash faster. The red light in your speedo is the light intended for the security system. This illuminates as you described when the BCU (Body Control Module) fails. Mine did it and so did several others with 2013 model bikes.
The BCU failure was likely caused by the change to LED lights, but the resister is not going to fix the problem. You will need a new BCU and it should be covered by warranty.
Old Mar 6, 2014 | 10:41 AM
Hot6's Avatar
Hot6
Same thing happened to me. The moco started using the BCM in 2012. When mine failed the bike wouldn't even run properly.
Old Mar 6, 2014 | 10:56 AM
128auto's Avatar
128auto
I hate canbus! Wait till you own an Audi, some models have over 30 onboard computers
surfnorthwest
Jan 19, 2022 10:43 AM
Jiggles
General Topics/Tech Tips
11
Nov 10, 2016 03:56 PM
hotrodbob
Apr 27, 2016 09:10 AM
blueridge
Jul 23, 2013 05:11 PM
xsnred
Mar 20, 2011 02:54 PM
