brake light problem (03 FXDX)
Old Mar 25, 2014 | 09:20 PM
supermanotorious's Avatar
supermanotorious
Default brake light problem (03 FXDX)
as far as I knew, my brake light was working but it's been a LONG time since I've looked at it to confirm, the tail lamp is always on so I assumed the brake light was good
I just bought some turn signals from Craigslist and the plugs snapped right in to the harness, after finishing the install with a custom light bar I fabricated I checked all lights to discover the brake light is not functioning, I can not say for sure the brake light was working before the install
I unplugged the turn signals but still no brake light, I checked the obvious, bulb and fuse are good
Out of frustration I stood really hard on the brake pedal and squeezed the brake lever and saw the brake light engage for a split second
I can not get it to do that again, any idea what might be wrong?
Attached Thumbnails brake light problem (03 FXDX)-001.jpg   brake light problem (03 FXDX)-007.1.jpg   brake light problem (03 FXDX)-002.jpg
Old Mar 25, 2014 | 10:08 PM
bobnehoc's Avatar
bobnehoc
Several things come to mind. Bad bulb, bad socket, wiring or brake light switch. Try a new build as they are cheap. Next check the socket with a vom. If no power is present either bad brake light switch or wiring issue. If that is the case check the wires that run under the fender as they can pop out of the loom and rub on the tire causing a short.
Old Mar 25, 2014 | 10:18 PM
maddghost's Avatar
maddghost
Change the bulb regardless it's an easy try if that's not it , only cost you a buck or so. I had my rear brake switch go could not get the brake light to engage with it but never both at the same time , that's why I'd lean towards the bulb itself
Old Mar 25, 2014 | 10:35 PM
supermanotorious
I did swap out the bulb with a brand new one from Scottsdale HD, I'm going to test for voltage at the socket now
Old Mar 25, 2014 | 11:35 PM
supermanotorious
grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr rrrrrrrrrrrrrrr
started testing the circuit board, I have good 12V when braking at the receiving side at the board but something goes wrong when I plug in the harness
I bridged the 12V giving lead to the receiving lead to bypass the harness but still the same issue
I then jumped the 12V giving lead to the receiving lead by cutting the receiving lead from the harness and still the same problem
IMO there is something wrong with the socket and I'm so frustrated, will call HD in the morning to see what the socket will cost
Old Mar 25, 2014 | 11:43 PM
slozomby's Avatar
slozomby
seems like a good time to upgrade to an LED tail light to me.
Old Mar 25, 2014 | 11:57 PM
supermanotorious
I wanted to mention that when the red/yellow brake light lead is NOT connected to the socket it reads 12V, when connected it reads about .65V and I DID test for a short in the socket via continuity but that test turned up negative
UGH
Old Mar 26, 2014 | 12:07 AM
supermanotorious
for f*ck's sake, I stood on the brake pedal again and got intermittent brake light, I don't know what the hell that means, I did good, solid electrical diagnostic tracing the issue to the socket but why would a crazy brake stand make it work intermittently?????
Old Mar 26, 2014 | 12:11 AM
slozomby's Avatar
slozomby
the sensor on the brake pedal loose?
Old Mar 26, 2014 | 12:13 AM
supermanotorious
A) I'm not sure how to tell
B) without the socket wired in, the R/Y leads read 12V with a moderate brake press
