Switchback oe Street Glide?
I lol'd when I read this. Same riding position as the RG, its whether you want your gauges and radio closer to you among other factors.
Some bikes will feel more comfortable than others. I do recommend taller shocks on the SG.
For those that say it sucks around town, are little refresher:
If you're considering those 2, you might also check out the Road King..
I'm a Dyna guy, so that would be my pick, but if I were going to do any significant distance touring I would have a SG.
Both are great bikes, you just need to actually ride each one and decide for yourself.
Having gauges is pretty awesome for those that like them though.
However, an aftermarket batwing style fairing looks like crap from the rider seat, IMO. Just an empty black space that could be filled with a radio and gauges.
if you are going to do touring then think touring bike.
Dyna bikes make good touring bikes up to a point. The biggest difference is the touring bikes are designed for touring in mind.
I am 5'7" and my SG fits me really good. Plenty of room for me and the wife. A good seat can give you more riders room.
It really is your choice so I am suggesting to take a good ride on each to see. Not a hour ride but a weekend ride. Remember you are use to a light weight Dyna bike. This is why I suggest renting one. If you make it understood you may by then they will knock off the rental fee if you buy. Most dealers will do that for you.
A dyna is far more maneuverable when pushing it, parking it, and doing u-turns. Especially when it's raining.
The Swichback has a 1.2" shorter wheelbase and weighs 92lbs less with different steering geometry.
AND since the Switchbacks one inch lower, I question the U-turn superiority. And u-turns are very common.
I don't recommend buying a bike for pushing and parking.
I DO recommend a bike for touring with audio, superior luggage capacity and a 1.3 gallon larger tank.
I DON'T choose my bikes based on the pushing and parking abilities, but then I'm a fit 6'2" and 220lb. But I know plenty of older riders, and riders with injuries that do consider such things. Size and weight may be considerations for the OP, which makes pointing it out relevant.
You seem to have decided the original poster, Spartanden, needs a touring bike. Had he actually said he wanted a touring bike, or even wanted to go touring you might have a point. What he does want is an upgrade on his Sporty that would be a tad more comfortable on trips - whatever that might mean - and has a screen and a radio. But he also likes the idea of a smaller frame.
I commute daily. The FLD runs rings around a touring bike, especially weaving around peak hour traffic on wet and greasy roads. A light scooter would be even better, but not my taste.
There are 2 main causes of vibration in the FLD, and only one is unique to it. The most common is caused by the stock muffler mounting which is easily cured by changing one of the fixed mounting bolts to a clevis pin (split pin) which allows the muffler to move independent of the bike. Bikes with aftermarket exhausts do not have the vibration issue.
Those that the clevis pin mod did not help, had an engine mount related vibration which is common across all Dynas because they all share the same mounts.
You should fix your wife's FLD so she can enjoy her bike.
