V&H Shortshots baffle mod
Old Apr 25, 2014 | 03:06 PM
kreeess's Avatar
kreeess
Originally Posted by glock35
I switched to the quiet baffle option, made it run a lot smoother with the mod. I am running the autotune now to see if that makes any difference. Put in quite a bit of time Friday and I am really liking it.
Should be doing this mod tonight afterwork since it's raining here in the Bay Area it'll give me someting to do lol, but besides the 1/4x1" thumb screw did u need anything else for this mod? Gonna stop by Home Depot before heading home from work
Old Apr 25, 2014 | 03:17 PM
1BRAVO9's Avatar
1BRAVO9
Last week I switched from the Big Radius 2n2 to the Short Shots and love the sound. I am completely satisfied for now but if I need a mod I know where to go.
Thanks for the tip.
Old Apr 25, 2014 | 04:17 PM
mojo6677's Avatar
mojo6677
Thanks for the info..was going to order bct baffles but will try this out first!
Old Apr 25, 2014 | 06:49 PM
glock35's Avatar
glock35
Just make sure you have (4) total nuts, (2) for each thumb screw. 1 nut goes inside the pipe and one outside. That's all you need.
Old Apr 25, 2014 | 08:55 PM
onecoolpilot's Avatar
onecoolpilot
I have the shortshots, but stock air cleaner and no type of tuner. Any idea how this will affect the A/F ratio for me? Would a little back pressure make it better?
Old Apr 25, 2014 | 08:58 PM
kreeess's Avatar
kreeess
Attempted to do this just now, seems like the screw that's in there now is pretty stuck, I might even have stopped the Allen bolt. Any tips? I postponed this project and proceeded to plasti dip my stock AC cover and horn cover lol
Attached Thumbnails V&H Shortshots baffle mod-image-3814098693.jpg   V&H Shortshots baffle mod-image-208289838.jpg
Old Apr 25, 2014 | 09:01 PM
JaronB's Avatar
JaronB
The back pressure will help because the short shots don't have much if any at all. Really the only time you have to worry about a tuner is when you change the air cleaner.
Old May 3, 2014 | 05:31 PM
onecoolpilot
Just finished doing this, took about 30-45 min, most of that was spent getting the heat shields put back on (those hose clamps just didn't want to cooperate).
Right off the bat I can hear a difference in the tone. The higher pitched raspy part is just about gone. I took it for a short "ride" around the block so I can't say how performance is, but I'll get to test that out next week. I wonder if some of the decel pop will go away?
Old May 3, 2014 | 07:13 PM
glock35's Avatar
glock35
I'm still happy with this mod. I'm sure the FuelPak FP3 has more to do with it than the baffle mod, but between the two (Done at the same time), my decel pop is almost completely gone. Overall my bike is just running much smoother now and it is still loud (which I like) but not so raspy.
Old May 21, 2014 | 09:43 PM
lokiwolf's Avatar
lokiwolf
It is amazing to me that I never thought of doing this with my short shots! I did the lollipop mod on my drag pipes I have on the Sportster and just never thought of doing it with the short shots. Brilliant man!
