Progress on my winter mods.
Old Apr 19, 2014 | 08:38 AM
blueangel73's Avatar
blueangel73
Default Progress on my winter mods.
Swapped out Street Bob trees for Fat Bob Trees (purchased from a forum member). This is how much wider the Fat Bob trees are.
The trees installed with stock SB legs, SB head lamp, SB wheel spacers and new Fat Bob/Wide Glide 25mm axle.
21"x3.25" wheel with a Wide Glide hub (completely built and purchased from a forum member) with new rubber and powder via the team at The Powder Pro.
New trees, wheel w/ new brake disk installed without the fender (fender was getting rivets drilled out and plug welded)
New Softail Deluxe style front fender (eBay buy) installed using brackets made by and purchased from Klockwerks.
New front fender and new rear (Klockwerks 180 kit) fender (purchased from them also at a great discount, bartering still works some places), the rear has the notch cut out for bag support crossover bracket. Also had multiple holes filled in on the rear fender because it was originally made for an older touring model to upgrade to a 180 tire.
The front fender brackets, you can see the I had to machine it down at both the shock mount and add some fender re-leaf to make them work.
Got the bags back on, with some minor spacing adjustments, the rear right bag stuck out about a 1/4" more then the left, I relocated the hole on the crossover bracket.
Now the fender and bags are more inline with each other, this fender has a 2" stretch over stock length, a 6" over was made but none were in stock. Now I just need to modify the filler panels to flow between the bags and fender.
I also got a great deal on two new (barely used) seat, the Mustang was a steal on eBay and the couch was a from the local dealership. Both seats together were cheaper the just one of them new.
Now to save up for a good paint job.
Old Apr 19, 2014 | 12:03 PM
Rainmakr's Avatar
Rainmakr
Looks great! Nice work...........
Old Oct 14, 2018 | 04:08 AM
Braaaappchaser's Avatar
Braaaappchaser
Default Part numbers
What's the numbers on the trees?
Old Oct 14, 2018 | 09:44 AM
woodguy75's Avatar
woodguy75
looks great, love the front end conversion
Old Oct 15, 2018 | 02:08 PM
Andrew4566's Avatar
Andrew4566
Very nice!
Old Oct 15, 2018 | 02:25 PM
Monteman1971's Avatar
Monteman1971
Looks nice....great progress!
Old Oct 15, 2018 | 03:26 PM
multihdrdr's Avatar
multihdrdr
That was several "Winters" ago
Since then, it has undergone a different set of Wheel/Tire changes and then later it was "Gone"
He has a Road Glide now
little squirt
Mar 6, 2013 04:04 PM
slaminum69
Oct 25, 2012 10:19 PM
jackyl
May 14, 2010 11:42 PM
mojojones
Jul 9, 2009 02:13 PM
JRK5892
Jun 12, 2009 06:29 AM
