Very Lucky Today
Old May 4, 2014 | 07:08 AM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
Originally Posted by dhook57
So I commute 24 miles one way to work and 14 of it is interstate which I do at a relaxing 70-75. I hit my exit and go to get on my brake and......the pedal is flat. The pin from the brake pedal to the brake rod has disappeared...and Im looking down at my pedal that is flat and level with my boards.
Luckily its a straight exit and not curving as I begin grabbing and releasing my front brake.
Pulled over and luckily got a ride to and back from a home depot 2 miles away. Put a 21 cdent bolt and nut on it and drove it to work.
Afterwards was just thinking how lucky I was to discover that while exiting instead of 1000 other situations where you need a quick brake.
Probably should get a lottery ticket.
Glad you made it through all that Top. As a earlier poster said back in the day using the front brake was not recommended for stopping except for an emergency.
Old May 4, 2014 | 07:13 AM
Bushranger's Avatar
Bushranger
Originally Posted by Chase1961
I remember a time when most people disconnected their front brake. Using the front brake was a big no-no. It would lock up and nose dive and either flip or you'd lose control.
Or on the old Brit bikes (40-50's) the front brake wouldn't work at all when they filled with water, **** my 65 trumpy has no brakes at all if i ride it in heavy rain and the drums fill with water,, so you got used to not using it, anyway locking up the back and sliding sideways while still having control has saved my **** 3 times, at least one of them if I'd hit the front I'd be dead. different traffic different times.
Old May 4, 2014 | 11:40 PM
EricInNCa's Avatar
EricInNCa
Brakes are over-rated. Just put your feet down. Fred Flintstone style...
OP: Glad you didn't panic and stopped ok.
lostrider06
Dec 25, 2024 11:35 PM
bigh8840
2014-2024 Touring Models
18
Apr 7, 2014 12:11 PM
Snap96
Jun 6, 2010 03:44 PM
dexterdave
Nov 27, 2008 12:58 PM
TOMMAY
Jun 15, 2006 12:26 AM
