Very Lucky Today
Old May 2, 2014 | 10:58 AM
dhook57's Avatar
dhook57
Default Very Lucky Today
So I commute 24 miles one way to work and 14 of it is interstate which I do at a relaxing 70-75. I hit my exit and go to get on my brake and......the pedal is flat. The pin from the brake pedal to the brake rod has disappeared...and Im looking down at my pedal that is flat and level with my boards.
Luckily its a straight exit and not curving as I begin grabbing and releasing my front brake.
Pulled over and luckily got a ride to and back from a home depot 2 miles away. Put a 21 cdent bolt and nut on it and drove it to work.
Afterwards was just thinking how lucky I was to discover that while exiting instead of 1000 other situations where you need a quick brake.
Probably should get a lottery ticket.
Old May 2, 2014 | 11:05 AM
JRK5892's Avatar
JRK5892
nice way to keep it calm and not panic man
Old May 2, 2014 | 11:11 AM
pab3rd's Avatar
pab3rd
Glad it turned out well, now hurry and get the quick pick on the lotto before the mojo wears off.
Old May 2, 2014 | 11:52 AM
DesertDyna's Avatar
DesertDyna
Front brake is your primary braking....sounds like you dont use it?
Old May 2, 2014 | 11:56 AM
IGOTTASRT8's Avatar
IGOTTASRT8
What he said. I use 99% front brake.
Old May 2, 2014 | 01:05 PM
gnstalodz's Avatar
gnstalodz
This isn't a sport bike. A lot of braking power and control comes from the rear brake. (yes still more braking power in the front though)
Glad you're ok OP
Old May 2, 2014 | 01:10 PM
Dirty Bay Bobber's Avatar
Dirty Bay Bobber
I had something like that happen to me not too long ago. but mine was the bolt that holds the brake pads into place. sumbitch backed out just enough to let the inner pad slip down so when i hit the brakes the calipers when to full extention. i got lucky and was able to gimp it over to the auto zone where the super nice manager let me borrow the tools to put it all back together... count your blessings.. could have been alot worse.
Old May 2, 2014 | 02:19 PM
DesertDyna's Avatar
DesertDyna
What does Sport bike have to do with it?? You're forgetting an important part of braking...weight transfer. Car, truck, motorcycle...doesnt matter. Front brakes stop ya...rear just help out. Most people will go through 2 sets of front pads before a rear set. just sayin.
Old May 2, 2014 | 02:32 PM
FXD_noob's Avatar
FXD_noob
The industry standard is 70% front 30% rear if I remember well...front brake is priority.
Old May 2, 2014 | 03:51 PM
will227457's Avatar
will227457
The real question is why did he need a ride to the Home Depot, the bike wasn't broken....
