Battery Meltdown on new FatBob
Old May 10, 2014 | 11:10 PM
upflying's Avatar
upflying
I would not touch it and told the dealer to bring a tow truck or trailer and to come get the bike.
Who knows what else burned up.
Old May 11, 2014 | 03:12 AM
Foxster's Avatar
Foxster
Just loose battery connections will do that. The heat of the arcing will melt the connectors and lugs.
For some odd reason Harleys are more prone to loose battery connections than any other bike I've known. The vibration?
Old May 11, 2014 | 08:47 AM
hdbob2006's Avatar
hdbob2006
That's what I would guess-loose cables. My softail has just the rubber strap holding the battery in.That lets the battery jiggle around just a tiny bit,and the cables work loose. I had to pack some insulation in front and back of the battery to keep it from moving.
Old May 11, 2014 | 09:06 AM
skinman13's Avatar
skinman13
I am going to play Devil's Advocate here...
I know from professional experience that this much heat damage can only be caused by a seriously bad connection or terminals shorted at the battery. The scenario you described is that you had just installed an after market light kit and subsequently had difficulties re-installing the battery and cover (was this because of the position of the new wire you installed???). Then the bike runs rough when you operationally checked everything before riding off into the sunset...
If you came into my repair station with that battery and this story expecting a warranty adjustment or new battery I would tell you to get bent also because...
Unless you KNOW for certain that you did not cause this damage and take your bike to them and agree to allow them inspect your bike for free to verify the cause, then you should not expect any warranty adjustments...In another life, I was in the business of providing maintenance services and this is a normal, sound, and reasonable business practice, and I think that you were in their position, then you would do the exact same thing.
I do not know the whole story...only you and the dealer rep you talked to know that...and I am not trying to be disrespectful, but maybe you might need to rethink this before going off on this dealer...Just say'n...
Good luck, hope you get this resolved and back on the road, and let us know how it goes...
Old May 11, 2014 | 09:10 AM
VIN1800's Avatar
VIN1800
What he said.
Old May 11, 2014 | 11:24 AM
saddlebag's Avatar
saddlebag
Originally Posted by case013
New battery went in smooth is working like a champ. Even pulled cover off a couple times today during my ride and checked to make sure it wasn't going nuclear on me. I can see how that conclusion might be drawn. Last time was more of making sure that fuse on the positive cable was laying just right and not cocked out blocking the edge of the battery box, but then again you never know. Something could have shifted when and lined up just perfect for meltdown. I do have that kind of horrible luck.
Did you install a current limiting resistor in series with the LED?
http://www.augustica.com/Electronics...g_Resistor.jpg
R = V/I. IIRC, LEDs need about 10 ma of juice to turn them on. Per the calc, 12V/10 mA = 1.2k Ohm resistor in there. If not, when that diode forward biases, you have essentially a dead short.
Old May 11, 2014 | 11:26 AM
case013's Avatar
case013
Awesome I love the devils advocate. Keeps ya honest. There were no new wires running to the battery. Just replacing old tail wiring new. I even checked all my electrical stuff(four years as an electrician in the navy so I'm reasonably sound here) after install. I installed everything and bike ran great for a few days then this happened. Rough start one day and I say rough but it took a little longer to catch than normal maybe an extra two seconds. Then next day dead. I KNOW the connections were tight because I checked them after moving that stupid fuse wire so it wasn't sitting on the battery strap.
I agree with the business practice. I didn't go in wanting a new battery or anything. I was just surprised at the full on laugh in the face when asking if the inspection or battery or anything could be put under warranty or what. I've just never had this happen with any of my other bikes and god knows they are anything but stock.
Anyways not trying to dealer bitch. Just wanted to show the guys a real head meet wall kind of day.
Old May 11, 2014 | 11:50 AM
JMC22's Avatar
JMC22
So, if the original dealership won't help ya and the next nearest HD one is 2 hrs away - what are your plans?
Old May 11, 2014 | 01:17 PM
bdtaylor1979's Avatar
bdtaylor1979
Originally Posted by SLV
That sucks! What caused it?
BTW, that would be the last time I went to that dealer. Your bike is brand new. I'd be calling HD about this one.
Agreed
Old May 11, 2014 | 05:09 PM
128auto's Avatar
128auto
Loose terminal to begin with, arcing from over time. That would be my closest guess.
fRESH88
Oct 23, 2019 03:51 PM
hapbob
Mar 5, 2014 05:28 PM
SlowwellScotty
Feb 4, 2014 02:57 PM
lh4x4
Jan 6, 2012 11:24 PM
Badbagger
May 2, 2008 05:14 PM
