Polyurethane riser bushings...increased vibration?
Old May 18, 2014 | 03:51 PM
Chinashop bull's Avatar
Chinashop bull
Poly bushings will not reduce vibration. Rubber is a better isolator. That said, I run poly bushings on my FLD with 1 1/2" risers and low Hollywood bars because I prefer the more direct feel.
Old May 18, 2014 | 05:13 PM
8541hog's Avatar
8541hog
True statement....
Poly are at their best on tall bars to help stabilize them, for short bars they really do not offer much that rubber does not other than longevity.
How the bars are torqued down will have a much bigger effect on vibration than the bushings, when replacing worn out bushings you would see a marked difference.
Old May 18, 2014 | 06:02 PM
zencaptain's Avatar
zencaptain
I felt a lot less vibration with the polys, other than at the stop light (which is more from the cam/top end kit). I can definitely see out of the mirrors better
Old Sep 30, 2021 | 03:25 PM
JatoTheRipper's Avatar
JatoTheRipper
I don't think a thin strip of innertube is going to do much for you. New grips and/or vibration damping gloves will serve you better.
Replacing worn rubber bushings will also help.
Old Sep 30, 2021 | 07:22 PM
DrewNJ's Avatar
DrewNJ
I've run both on my fxdf. Seems the difference is where the vibes are most noticeable.
For me rubber was better at idle but poly was better at speed. Different strokes.....
Old Sep 30, 2021 | 07:34 PM
MURPHCC1's Avatar
MURPHCC1
pretty sure he figured it out 7 years ago.......
Old Sep 30, 2021 | 09:45 PM
JatoTheRipper
Doh! Sorry, my bad! I have no idea how I got to this thread if it was this old.
TejasJeff
Sep 12, 2017 09:44 AM
Rollon
Jun 18, 2014 06:10 AM
wraplock
Jun 3, 2014 03:04 PM
wraplock
Jul 24, 2009 06:49 AM
ronyd
Oct 9, 2007 08:42 AM
