Ignition switch moved - Street Bob
Old Feb 9, 2008 | 05:52 AM
  #61
evil cetane's Avatar
evil cetane
Default RE: Ignition switch moved - Street Bob
Well I kinda f**ked up on this mod.
Things I learned:
1. Buying the switch from JP with the 3 prongs makes this mod easier
2. The switch from JP will be shorter then the one used in the first post of this thread
3. figure out number 2 before cutting the hole or your f**ked
4. if you buy a hole saw and the package says 2", check the bit itself because it maybe a 2"1/4" bit in a 2" box. And, well, your F**ked
5. if you cut a hole to fit a grommet and plan on mounting the switch to a plate on the tank, well your f**ked
6. If you realize this after your on to assembly, you will be calling the dealer and forking over 100 bucks for a new dash.
Although i got the switch working with a little hack job, I will be redoing it a little better next week. One thing I did do was build a wire Harness for the ignition. this came out looking stock. I want the switch housing to look stock also, so I will cut the hole 1/32 to small and rotor sand it out for an exact fit with no grommet. Then use the four mounting holes form the switch through the dash with harley Allen nuts.
BTW, Im f**ked
Old Feb 9, 2008 | 06:40 AM
  #62
DougsDyna's Avatar
DougsDyna
ORIGINAL: evil cetane
Things I learned:
BTW, Im f**ked
There's the "hard way", and the other way.............. I never learned the other way
DougJ
Old Feb 9, 2008 | 07:14 AM
  #63
whannigan1's Avatar
whannigan1
Good Job
Old Feb 9, 2008 | 12:16 PM
  #64
amish's Avatar
amish
Things I learned:
BTW, Im f**ked
got a pis of the finished product?
Old Feb 9, 2008 | 05:32 PM
  #65
matkiwi's Avatar
matkiwi
Things I learned:
BTW, Im f**ked
We've all been there ...
Look forward to seeing version two ... photos please !
Mat
Old Feb 10, 2008 | 12:48 PM
  #66
evil cetane
ORIGINAL: matkiwi
Mat
Well, since I am getting a new dash this week, i decided i didn't need to make it look pretty. So i just mounted the switch on a plate an shot some sheet metal screws threw the dash. The stuffed a sliced vac line around the hole to fill it in. I just needed it running, I ride year round. Looks like crap.So no photos 'cause I would be embarrassed to show it. When I re-do it i will show everyone what it looks like then.
Well this is unless you would like a demonstration on how NOT to do this mod?
Old Feb 10, 2008 | 01:16 PM
  #67
HD4DP's Avatar
HD4DP
Did mine. Here is a pic.
Old Feb 10, 2008 | 01:21 PM
  #68
kk6pg's Avatar
kk6pg
That might not be a bad idea. We rarely hear or see when things go wrong, only the perfectly finished project.
Old Feb 10, 2008 | 02:46 PM
  #69
07denimbobber's Avatar
07denimbobber
hey guys nice mod....
i bought the switch on ebay with the three male prongs for $22
am looking forward to install
Old Feb 10, 2008 | 05:01 PM
  #70
reded's Avatar
reded
Got my grommet from cableorganizer.com
part# O-RPD-G3311
2"X1/8"
