FP3 rev and idle settings
Old Jun 12, 2014 | 04:22 PM
! rock103 !'s Avatar
! rock103 !
Default FP3 rev and idle settings
Hey all, I just installed the FP3 and feel it has been a great improvement. I have a few question for you all and hope I can get some sound advice about the rev limit and idle setting. I thought about lowering the idle and raising the rev limit a couple, say 200 rpms. Any potential problems, thoughts, concerns? I talked with Vance and Hines tech support and they feel a few hundred rpms shouldn't be a problem. But said they can't recommend a particular setting other than the base map. Thought I would shoot out the question for conversation and consideration sake. Thanks all!
Old Jun 12, 2014 | 04:57 PM
adm's Avatar
adm
I read you shouldn't go below 950 rpm on the idle or the oil pressure may drop too low...
Old Jun 12, 2014 | 05:07 PM
HD Bobber's Avatar
HD Bobber
Stock thundermax maps are set at 894 (at least the ones for dynas and few baggers maps I dealt with). Saying that I still raised my idle to bout 955 and feels more at home there.
As far as the rev limit I would set it at 6200 w/o problems.
Old Jun 12, 2014 | 08:17 PM
rdss's Avatar
rdss
I've thought about adjusting those settings as well, I think next time I'm thinking about it I'll set my idle to 970 and move the rev limiter to 6,200. I've also been wanting to auto tune but have been scared off by the issues Apple devices were having.
Old Jun 12, 2014 | 08:24 PM
! rock103 !
Thanks guys, the rev limit is already set at 6200 and I bounce off it from time to time. Thought of raising it to 6500ish
Old Jun 12, 2014 | 09:12 PM
HD Bobber's Avatar
HD Bobber
If you only have intake and exhaust it won't benefit anything from 6500. Besides the performance upgrades 6200 it a safe limit on a stock(untouched) harley crank. To go into the higher r's the bottom end should be beefed up (trued, welded, balanced crank, and better rods will allow u to rev the **** out of it w/o grenadine your motor.
Old Jun 13, 2014 | 09:35 AM
! rock103 !
Ya, I'll probably leave the settings alone.
Old Jul 30, 2018 | 08:20 PM
zobell's Avatar
zobell
Question fp3 rpm's
So I installed mine today,took all of ten mins.Went for a ride and was like my bike must have been really out of tune,seriously to feel that much difference.
But I notice one thing after 20 mins or so,my rpm's are running a grand higher in all speeds ??? IS THIS THE SECRET SAUCE ,amazing results are because the engine running 1000 rpm higher and feels a shot of steroids?Anyone care to comment am I totally wrong?
Old Jul 30, 2018 | 09:52 PM
tcazes's Avatar
tcazes
I'm surprised to see a recommendation of 950 for idle. My map from thundermax has my idle at 816
Old Jul 30, 2018 | 10:55 PM
Davdoodles's Avatar
Davdoodles
Not sure what you mean by this: "my rpm's are running a grand higher in all speeds"?
As delivered, HDs EFI maps are set way too lean, in order to comply with emissions laws.
A tuner will typically give you significantly more power, or move your peak power up or down the rev-range a bit. It does that by changing how much gas is mixed with the air, altering the spark advance curve, etc. They really do make the bike run much better. How it should run...
But a tuner can't change the revs your engine is doing compared to the speed you're traveling. Only being in a different gear, or having a slipping clutch (or doing a burnout ) will do that...
