06 SB backfire through A/C question....
Old Jun 13, 2014 | 08:12 AM
03geetee's Avatar
03geetee
Default 06 SB backfire through A/C question....
Guys,
Stock motor bike, Harley Stage 1 download, heavy breather A/C, Python Staggered duals otherwise 100% stock. Started it yesterday (75 degrees out) after sitting in lot for 30mins and she turned over a bunch then coughed smoke out of the air cleaner. This happens once in a while, what the hell causes it? Bike runs fine after just annoying.
Thanks
JTR
Old Jun 13, 2014 | 08:59 AM
maddghost's Avatar
maddghost
Freaked me out the first time, a long time ago. There is no special cure except how you time your starting. It is a full stage I so here is my suggestion unless you already do this. Turn on the key and kill switch in neutral and the second you hear your pump come on hit the start button. I've been doing this for years. This is especially good when you just stop and go for gas and she is still hot.
PS hold that button till she starts!
Old Jun 13, 2014 | 09:07 AM
03geetee's Avatar
03geetee
Might be my issue I always wait to see the check engine light go out (4-5secs tops) then start. I will try starting it quicker and see if that helps.
JTR
Old Jun 13, 2014 | 09:10 AM
maddghost's Avatar
maddghost
I practically guarantee it. there is not one HD tek who waits to see that light go out. Only the sales people wh have to cover their butts!
Old Jun 13, 2014 | 10:28 AM
Foxster's Avatar
Foxster
Some of your problems might be that you have just the dealer download. That doesn't do anything other than raise the rev limiter a bit. Even just adding some Xieds would probably help but a proper tuner is likely the real answer.
flyboyron
Apr 12, 2014 08:34 PM
Mercyfulfate
Sep 3, 2013 01:09 AM
Rob2002
Jun 18, 2007 12:00 PM
smokermike
Jun 12, 2006 03:48 AM
oldfartjc
Mar 2, 2006 09:35 PM
