Progressive monotubes
Old Jan 3, 2015 | 10:28 AM
  #71
SquidHead's Avatar
SquidHead
Originally Posted by Ironhead.Chris
Thanks for all of that info Squidhead!
Which spring are you going back to on your next setup? The Traxxion single rate or the Works triple rate and why?
Thank you,
-Chris
I'm actually saving up for the Ohlins cartridges the Howard at Motorcycle Metal has modified to work with 49mm forks.
BUT, if I was gonna go back to springs, Works all the way. The ride was so much better with them because I was able to dial in the feel just where I liked it. The single rates are great too, but not as adjustable.
Old Jan 3, 2015 | 05:12 PM
  #72
Ironhead.Chris's Avatar
Ironhead.Chris
Thanks man, I really appreciate the info.
-Chris
Old Jan 3, 2015 | 05:36 PM
  #73
brandon2684's Avatar
brandon2684
Anybody try the Works drop in cartridge?
Old Jan 3, 2015 | 10:26 PM
  #74
07bobber's Avatar
07bobber
Anybody able to compare the monotube kit vs a race tech setup?
Old Jan 3, 2015 | 11:38 PM
  #75
Tat2u's Avatar
Tat2u
thanks for the review, gotta say im hugely disappointed, I was going to run with a set of these...
Old Jan 4, 2015 | 06:40 AM
  #76
VIN1800's Avatar
VIN1800
I changed from Traxxion spring and Ricor intiminators to Progressive Monotubes. Monotubes is the best set up by far. Just my opinion but Monotubes is a very nice set up.
Old Jan 4, 2015 | 09:31 AM
  #77
Ironhead.Chris
Did you mean the spring setup is the best but monotube are nice setup or you actually like the monotube over your spring setup? Sorry, your statement sounds like you meant the first thing but said the second thing.
-Chris
Old Jan 4, 2015 | 10:00 AM
  #78
VIN1800's Avatar
VIN1800
-Chris
Sorry, monotube set up is way better for me then spring/ricor set up. Spring set up with ricors always seemed harsh/stiff.
Old Jan 4, 2015 | 06:05 PM
  #79
Ironhead.Chris
It's cool, I just wanted to make sure I understood what you were sayin. How was your front end dive during braking with the Monotubes?
-Chris
Old Jan 6, 2015 | 10:25 PM
  #80
speedkills66's Avatar
speedkills66
I'm going to install the monotube kit this weekend....
Did you adjust the steering head fall away after reinstalling the forks in the trees per the manual?
