fuel filter change
Old Jul 10, 2014 | 10:09 AM
maddghost's Avatar
maddghost
Spark plugs should be fine for 2 years easy with periodic maintenance. If your poles are tight at all four ends and the headlight is bright it can't very well be the battery. Does it splutter only if your sitting on it or any time it chooses, because you know I'm leaning towards crushed or melted wires under the seat going back to the electrical caddy. Ask me how I know this!
Old Jul 10, 2014 | 05:38 PM
HoolyNI's Avatar
HoolyNI
Took that lead off but couldn't see anything obvious, pressed the silver nipple and got a spray of petrol in the face, so it works alright lol.
Thought I noticed an improvement riding home but still wasn't right, idles ok but rough as a badger thru traffic in first, jerky with no real throttle control.
Checked leads under seat as far as I could but none seem damaged.
Old Jul 10, 2014 | 06:43 PM
SuperFastGlide's Avatar
SuperFastGlide
if your speedo is dropping to 0 and your bike spuuters or dies while your cruising you most likely have a battery connection problem
Old Jul 12, 2014 | 03:22 AM
HoolyNI's Avatar
HoolyNI
Default Sorted....
Had the battery checked yesterday and despite being the 9 year old original and having a dodgy positive terminal it is still working fine.
Tried 2 new plugs as a last resort before going in to change the fuel filter and viola, it was the plugs all along :-)
Fuel filter etc can now wait till major overhaul in winter.
Thanks all for your input.
Old Jul 13, 2014 | 02:36 AM
harley66140's Avatar
harley66140
Originally Posted by HoolyNI
Thanks for detailed response. Have been on with local dealer to price parts for a filter change and some seal I need for tank is actually more expensive than the filter itself...they don't seem aware of the 12 screws that need replaced too...
On my winding operation, I have not changed the screws. No problem since!
Old Jul 13, 2014 | 06:51 AM
stilup's Avatar
stilup
I just went through a miss at high speed.
Came home and did a once over,
New plugs, spark plug wires,removed the air cleaner and used throttle body cleaner and gave it a good cleaning, removed the crank sensor and cleaned it,
Also replaced the battery,replaced the system relay.
Problem solved, runs fantastic.
What cured it? Who knows.
128auto
Sep 1, 2019 09:31 AM
Yankee Dog
EVO
20
Sep 12, 2018 09:16 AM
storrey69
Sep 27, 2014 05:11 AM
0204665J
Exhaust System Topics
Aug 25, 2007 06:48 AM
vernh59
Jan 11, 2006 03:39 PM
