Powervision/tuning experts, need support.
Old Jul 14, 2014 | 11:15 AM
JayOhh's Avatar
JayOhh
Default Powervision/tuning experts, need support.
I got a 103" with a PM intake, D&D exhaust and se-204 cams. Dealer installed all of this before I picked her up.
Ordered the Powervision from Fuelmoto with a preloaded map. The map says "TW-555", which made me wonder if they loaded the wrong map. But they answered my e-mail with it was the closest they had, and I should do some autotune-runs.
Well, bike was sputtering and behaving badly when cold on low rpms. After some autotuning that is fixed.
Still a lot of backfiring when I release the throttle ( which doesn't really bother me ).
But the last week or so, I think my motor's been pinging. Strange noise when I give full throttle, then goes away. It's been 90 degrees for the last couple of weeks, which is waaay more than it usually is up here in northern Norway, so that might be a cause of the pinging (?)...
Bike is not dynoed, and I really don't wanna do that either untill I go stage3 ( 8 hour ride to nearest dyno-center, and probably $700-$800 ).
So is a good dyno the only cure, or can any of you experts help me out? Manual map-setup maybe?
Old Jul 14, 2014 | 11:49 AM
Grendel4's Avatar
Grendel4
Yeah, because the SE 204 is such an uncommon cam, right?
I don't see the TW 555 and the SE 204 as being even remotely similar.
.555 lift vs .508, duration, lift at TDC, 30 degrees of overlap as opposed to 40, open/close timing.
I also think the SE 204 is one of the best cams going. Highly underrated.
Wish I had one but I didn't want to go through what you're going through and didn't want to spend the money for the SEPST and the requisite TTD (test to destruction) time on the dyno.
Good luck. Let us know how you make out
Old Jul 14, 2014 | 12:02 PM
JayOhh's Avatar
JayOhh
I know. Only reason I ordered from them, was because of the good cutomerservice, and they're supposed to have the largest map-library in the world hehe... So I was a little bit surprised that they didn't have a 103" with the Se-204 and sent me a map with completely different cams.
Just sent them a new email ( " allow up to three businessdays to recieve your map" ). Hopefully they will sort this one out....
JayOhh's Avatar
JayOhh
I know. Only reason I ordered from them, was because of the good cutomerservice, and they're supposed to have the largest map-library in the world hehe... So I was a little bit suprised that they didn't have a 103" with the Se-204 and sent me a map with a completely different cam.
Old Jul 14, 2014 | 12:10 PM
HD Pilot's Avatar
HD Pilot
If you are patient(Fuel Moto is a busy place), they will fix you map. Might have to email your tune back and forth a bit but it will be taken care of. Might just give them a call about your particular issues and they will tell you what to adjust - need to be on the step with WinPV though.
Hopefully you are not getting backfire but just decel pop.
Old Jul 14, 2014 | 12:27 PM
maddghost's Avatar
maddghost
The autotune pro from dynojet is supposed to be capable of tuning your timing to stop the pinging. Mine will ping too if I give it too much gas all of a sudden. What grade of gas they sell in Norway and warm humid weather are certainly factors. I try to twist the throttle steady and slow until full open rather than suddenly and your at full open throttle.
The theory about the atotune pro is that you tune correcting VE tables which is first and most important. once you see the biggest changes are getting minute you then go into Winpv and turn max fuel learn to 0 and turn max spark learn to 10. This gives the ecm lots of extra timing and the autotune takes out what it does not need. After that you put the AT pro unit back in the box, remove the WB O2 sensors and replace your narrow bands and then forget about tuning for a while. --> but you need to have the AT pro to do this. So you will need that dyno.
Around here the original dyno costs alot, but if something gets changed later it only costs a fraction to rectify.
Old Jul 14, 2014 | 02:32 PM
JayOhh's Avatar
JayOhh
Yeah I don't have the Pro-version, only the basic.
Hoping Fuel-moto will come back with a response, I send them the log from my last session. Anyways, this hot weather will probably be over in a day or two.
We use 95/98 octane over here ( I'm using 95 ). But it's a different system than in the US, so you can take away 3-4 points. Prabably the same as yours 91.
If the pinging doesn't go away, and Fuel-moto won't be able to help, I'll just try the 98 and see if that helps.
PS! Going easy on the throttle is not an option
JayOhh's Avatar
JayOhh
Old Jul 14, 2014 | 04:44 PM
target64's Avatar
target64
you guys got to learn these maps are to bring it in close and have it run able. but you take a look at most maps there is no timing added and the VE tables will be off also you can take a map with it adjusted for sea level and expected it to be right for 1500 ft above or higher and with addition of cams things are going to be different. proper method get it tuned if all your motor work is done.
Old Jul 14, 2014 | 06:43 PM
maddghost's Avatar
maddghost
HAHA I hear you on the throttle thing and I get it open just not from let's say 12% throttle to 100$ full open in one 1/8th of a second. Whenever I'm in the staes I can get the 93 gas, my bike runs stronger - no pings, and more mileage from a tank. If the 98 doesn't cost you too much more then definitly I would buy that gas.
