Adjustable shifter linkage for mid controls
Old Aug 2, 2014 | 01:17 PM
Julia's Dad's Avatar
Julia's Dad
Default Adjustable shifter linkage for mid controls
Just in case that this would be helpful for somebody else also.
I had a hard time getting the shifter adjusted after installing the Kuryakun mini floorboards to my 2013 FXDB as the stock shifter linkage arm was non adjustable and the grooves in the shifter shaft were too coarse to allow for correct shifter arm angle. Either my boot would not fit under the shifter or the shifter was way too high.
Found this adjustable shifter link from Bungking. Stainless steel and very rigid compared to the flimsy stock part. I can see the stock shifter link breaking up at some point as it seems to be a real cost reduction part. Apart from the adjustability the new linkage made the shifts also much more precise than before.
Old Feb 16, 2016 | 10:11 PM
sdrawkcabssa's Avatar
sdrawkcabssa
Hello! I have considered doing this exact modification on my 16' Street Bob, I realize this is an old thread but thought I would see if you might answer some questions. After doing this mod, did you find that you scraped the mini floor boards more often when cornering? Did you find these to be more comfortable on long rides/in general? Did you end up keeping them on for a while, or still have them on, and would you recommend this mod? Did you torque the bung King shifter linkage to a particular inch lbs? (don't think they mention that in the manual)
Thanks for humoring me!
Old Feb 17, 2016 | 12:31 PM
Julia's Dad
There was nothing wrong with that setup but I didn't have it on for very long. I always felt bit cramped with the mids and the mini-floorboards did not completely solve that issue. Forwards never felt right to me. There was no more scraping than with the standard setup. I did not tighten to any specific torque but not too tight and used loctite of course.
I ended up with full floorboards. Could not be happier and don't see myself going back.
BTW, I very much dig the color of your bike!
JD
Old Feb 17, 2016 | 02:00 PM
dyna rider's Avatar
dyna rider
Default Adjustable Shift Linkage
Harley sells that same linkage in chrome...I have had one on my bike for almost 10 years.
Old Feb 17, 2016 | 11:25 PM
sdrawkcabssa
JD
Hello, thanks for the prompt reply, and answering all my questions. That set up you have now looks legit, I bet it took a lot of work to figure out. I guess I'll have to give the mini-floorboards a try and see how they work for me. I prefer the mid position when I'm riding more aggressively - but pegs are just not adequate for longer rides. Glad to hear you didn't experience clearance issues. And - thank you!
m6zero
Feb 19, 2015 08:32 PM
Greg Di
May 21, 2014 04:57 AM
seamus
Mar 14, 2014 04:29 PM
medina charlie
Mar 16, 2010 09:18 AM
Demonsmasher
Mar 27, 2008 09:29 PM
