Something is Loose!
Old Aug 18, 2014 | 08:33 PM
Razorback Rob's Avatar
Razorback Rob
Default Something is Loose!
I've had my new bike a week or so. At first, the damn thing vibrated so much, I didn't notice it, but I put these SE mufflers on it, that got rid of a lot of the vibration. Anyway, I started noticing that every time I hit a bump, something moves. I feel it from my feet back. I was wondering if anyone has ever had this problem. I'm taking it to the dealer on Saturday to let them look at it. I was just curious in the mean time. I checked the battery, it's solid.
Old Aug 18, 2014 | 09:03 PM
nevil's Avatar
nevil
Check the exhaust mounts and every other fastener. This is something you should do every now and then anyway. Put a wrench on the tank bolts, they may seem tight but even a 1/4 turn can make the difference.
Old Aug 18, 2014 | 10:49 PM
amfhd's Avatar
amfhd
I had the same thing on my 06 Super Glide. Almost like the rear motor mount was loose.I have replaced and shimmed my front motor mount and gone over all my motor mount bolts, I don't notice it anymore. I don't know if I got used to it or if it went away. As for vibration, my old shovel is way smoother than my Dyna, at least up to 70-75 mph. My Dyna definately feels best mid to upper rpm's.
Old Aug 19, 2014 | 12:12 AM
jmb79's Avatar
jmb79
Check to make sure the bolt holding your seat in place is tight. I've seen those be pretty loose.
Old Aug 19, 2014 | 08:48 AM
f-250ford's Avatar
f-250ford
Check to see if your shoes tied.
Old Aug 28, 2014 | 10:06 AM
Dethroned666's Avatar
Dethroned666
3rd Gear
Second that. After riding my 2010 FXDWG swapping to my shovel (81 FXEF) it feels like flying on a carpet. Incredible that 70s suspension is better than 00s... Even back then it wasn't all that...
Anyway: I have the same problem as TS: when I'm hitting bumps it feels like something is hitting almost metal on metal (more like: metal hitting rubber), so it MIGHT be the engine hitting the front motor mount which I've spaced to 1 mm from the engine (factory spec) and on the other end with some washers to the frame...
I guess it comes with how the bike's constructed. Doesn't feel right though...
Old Aug 28, 2014 | 04:36 PM
HyperM3's Avatar
HyperM3
I recently found my steering head nut to be not torqued to spec. Did that with a torque wrench to make sure it was correct and now I dont feel the same looseness as I did before. Check that out.
Old Aug 28, 2014 | 06:05 PM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
You say every time you hit a bump something moves.. I have that problem too it is my butt from having to ride these rough *** okie-homer roads. Seriously though it may be your motor mounts.
Old Aug 28, 2014 | 06:16 PM
Galdog's Avatar
Galdog
A couple years ago, when I hit a bump, I heard a clunk. Drove me nuts, front gas tank bolts were loose.
RobPic
Aug 17, 2011 05:33 AM
R_W_B
Dec 3, 2010 11:34 AM
masplumber
May 24, 2010 11:20 PM
Hdbiker1450
Exhaust System Topics
Nov 21, 2007 06:02 PM
mhbetzer
Sep 21, 2006 04:03 PM
