Need some leg room
Old Aug 20, 2014 | 05:12 PM
ss243b's Avatar
ss243b
Default Need some leg room
Just got an 08 super glide, it has forward controls on it and what im guessing is the stock seat. I still feel a little bunched up, would like to stretch out a little more. Any options? are all forwards made in different lengths? Also my foot break is way to high it seems and i dont think its adjustable, i either have to ride with my foot barely on the brake or under it on the peg but to get back to the brake i have to move my whole leg out and back because im bunched up, im 6'2" 34" inseam.
Thanks guys, i will get some pictures up asap
Old Aug 20, 2014 | 06:00 PM
nathanw's Avatar
nathanw
6'7'' w/ tree trunks for legs. Lapera bare bones puts you further back and 3'' forward controls have me plenty comfortable.
Old Aug 20, 2014 | 06:08 PM
sisson16's Avatar
sisson16
You can adjust the placement of the brake lever with the linkage.
Im 6'3" and have 3" forward extensions i bought used off ebay and had them coated and ive got a C&C fastback 2up seat. The seat sits you slightly lower and back further. I had the seat before the extensions and it alone made a difference.
Old Aug 20, 2014 | 06:35 PM
ss243b's Avatar
ss243b
Old Aug 20, 2014 | 06:37 PM
ss243b's Avatar
ss243b
i see how to adjust the shift lever, but that brake lever kinda got me confused, also it rubs the mount, its like i need another 2" or so out
Old Aug 20, 2014 | 07:53 PM
sisson16's Avatar
sisson16
Look at the rear by the master cylinder. You'll have to take the front loose from the pedal then adjust the length at the rear of the linkage.
Old Aug 20, 2014 | 09:00 PM
nathanw's Avatar
nathanw
The adjustments are limited. When you have very long legs ( like you and I do ) your foot will end up at a funny angle due to the bend in your knee. If the pegs were further away this would be mitigated significantly.
Old Aug 20, 2014 | 09:07 PM
ss243b's Avatar
ss243b
yeah, its just enough to annoy me, im gonna mess with moving the shift lever and break lever around and try to find a happy medium
ss243b's Avatar
ss243b
Thanks for the help
Old Aug 21, 2014 | 09:49 AM
spyderwebb's Avatar
spyderwebb
You can adjust that down a couple of inches from it's current position it looks to me, check out mine in the attached photo and see what I mean.
Looks like the forwards on yours are in about the same place as mine but my brake pedal is much lower. It was like yours when I bought it (must of been a shorter dude) and I could not brake without lifting my foot off the peg.
You want it to where you can apply the brake by merely pressing your toe down while comfortably resting on the peg.
